1997 v70r if i (accelerate)hard it loses power
chuffin hell
- Year and Model: volvo v70r
Well same running bad must of been coincidence
Weres fuel relay
Weres fuel relay
- Has thanked: 2203 times
Hi Adam,
I am fairly sure your 98 will be the same as mine with '2' fuel pumps. As the fuel tank is like a saddle there is a second pump (although Volvo call it something else and it has a pipe that runs across the front of the fuel tank to the main pump.If the 2nd pump fails, then you don't get the whole fuel tank worth of gas, but also there is a pressure regulator on the other pipe from the 2nd pump that runs over to the RH rear of the top of the fuel tank. I'll try to find a post I did giving the details of all the fuel pipes and emissions stuff on my 2000 R.This may be a little different to your car as things changed in 1999 and 2000.
https://www.matthewsvolvosite.com/forums ... =1&t=69887
Have a read at that and it may help you see more of what is at the back. Your car is AWD?
There is also a second valve that is part of the fuel rail assembly that is known to fail. It is if I recall on a 98, at the Cam-belt end of the rail and underneath it.
chuffin hell
Am getting no where
Fuel pressure is good under load
All vac pipes changed
Turbo works fine
Good vacuum
Turbo works fine
Good vacuum
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
But have you changed the TCV?
You're overboosting or overloading the TCV w/ the chip, that'd be my guess. Since everything works, lines and hoses are changed and there's fuel, then as some others have said, there are control issues.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
chuffin hell
Sorry yes tcv changed for a good one no difference so changed back
Sommerfeldt
Yeah, but if you just switched one out for another like it, then the problem would likely be the same anyway... Since everything's working, your hoses are good, the car starts, runs and boosts, then you've a problem with control.
You have to take note of what Neil and abscate said - what's your boost pressure? Higher than ~14, and you likely need a different TCV all together.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
chuffin hell
Hi yes I've lowered boost to 12 .it used to run great before problem at 18 psi
I will re check everythin again
Sommerfeldt
Well, if everything works at 12, and you don't get the cut-out, then you've got your culprit right there.
So I'm assuming that you have an MBC, and you cranked the boost up to 18, and then the troubles set in?
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
chuffin hell
No everything not better still runs bad
- 1414 Views
Last post by hvsk
- 1079 Views
Last post by xHeart
- 600 Views
- 20 Replies
- 5046 Views
Last post by guidowitz
- 1370 Views
Last post by sbattaglia
