I've tried jamming a rag down into the recesses atop the engine (not the spark plug holes) to absorb the oil but it's not getting up as much as I'd like. I've read about using brakleen (red can) to get rid of oil, any feedback on that or other suggestions to get all the crap out?
1999 V70 T5 - doing a bunch of maintenance!
petermetzger
- Year and Model: 1999 V70 T5
Quick question - any recommendations for cleaning off the top of the engine (around the spark plugs/coil packs)? There's quite a bit of oil collected up there from whatever was causing it (hopefully PCV and/or oil cap seal since I just replaced those
) along with plenty of little bits of broken, brittle wire harness. I'd really prefer not to let any of that junk fall down into the cylinders when I change spark plugs.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
What I will do on mine is remove all the little electric and sensor stuff, give it a clean with something like Simple green, then paint it. I paint the intake manifold while it was out for the PCV job and it looks clean
petermetzger
Good call, I had somehow forgotten about Simple Green but it's good stuff!oragex wrote:What I will do on mine is remove all the little electric and sensor stuff, give it a clean with something like Simple green, then paint it. I paint the intake manifold while it was out for the PCV job and it looks clean
I got tired of doing engine work so for a change of pace I removed the struts to replace the bearings, spring seat/bushing, and mounting hardware. I had ordered the kit from FCP a while back but never got around to using it. Somewhere along the line today I decided the struts were too worn out to be worth putting on so I ordered a pair of Sachs (OEM) struts to install. The Bilstein touring struts were tempting but the added cost was just a little too much to swallow since the purchase sort of came up with short notice.
Photos to come in the next couple of days!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I usually use a decent cloth rag and a screw driver. You can vacuum that plastic up.petermetzger wrote:
I've tried jamming a rag down into the recesses atop the engine.
petermetzger
Just a quick update - I installed new front struts/hardware (still using old coil springs) last night so that bit is all buttoned up
I also replaced the tailgate struts which had worked fine in warm weather but always fell down when the temperature got a little cooler. Going to get back to the engine work this afternoon to try getting everything cleaned up there!
Great idea with the rag/screwdriver combo, Robert! I'll be giving that a try today
- 343 Views
Last post by jreed
- 20 Replies
- 5028 Views
Last post by osman
- 1004 Views
Last post by ems_kws
- 20 Replies
- 3594 Views
Last post by TheOtherside
- 21 Replies
- 2661 Views
Last post by MagnificentSin
