98 V70 gas tank - possible vapor build up issues
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
So its been a few fill ups and many days since I replaced the purge valve and the filter. No codes since, no shut off of the gas pump during fill-ups since, no swoosh of vapors when removing the gas cap since. Apparently either the purge valve or filter or combination of both wasn't allowing the system to purge.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Sorry for the delayed reply to your question a week ago. Yes, there are two electrically actuated valves in the system, a purge valve and a vent valve. The purge valve is mounted near the radiator in the engine compartment. The vent valve location depends on model year. On the '97 it is behind the front wheel on the driver's side. On the '98 I think it is located near the gas tank.
98v70dad
On my car, a 98, there is an electronically actuated valve on the aft side of the drivers side wheel wheel. I know its there because I've replaced it and it was a royal pain to do. Most people refer to it as the rollover valve. I have nothing electrically actuated in the rear near the gas tank that I am aware of.jreed wrote:Sorry for the delayed reply to your question a week ago. Yes, there are two electrically actuated valves in the system, a purge valve and a vent valve. The purge valve is mounted near the radiator in the engine compartment. The vent valve location depends on model year. On the '97 it is behind the front wheel on the driver's side. On the '98 I think it is located near the gas tank.
- Has thanked: 311 times
- Been thanked: 817 times
Rollover valve is a strictly mechanical thing, turn it over and it closes, no electronics (that would defeat the whole purpose). Pretty sure they are only back near (just aft of) the fuel filter.
There is a tangle of stuff on top of the gas tank, maybe that is the location jreed is referring to? You would never see it unless you dropped the tank, or did some serious poking around with the fuel pump hatch up.
- 16 Replies
- 829 Views
Last post by Brickbox8398
- 11 Replies
- 12723 Views
Last post by MagicMike
- 15 Replies
- 1032 Views
- 16 Replies
- 10562 Views
Last post by EdRedSled
- 1119 Views
Last post by sherry007
