1998 S70 T5 PCV relief?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
erikv11 wrote:
rspi wrote:
mar601 wrote: The guy at Volvo said also that sometimes the PCV problem can create turbo problems (leaks etc). ? ?
Is this tread real? I feel like this is myth busters for Volvo's.
Tons of PCV's are bad and need/have been serviced with NO effect on the turbo.
A super clogged PCV will dump oil into the turbo and pour smoke out the exhaust, my GLT was like this when I got it.
That did NOT damage the turbo, just blew oil through the piping.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
I just pulled the 15G turbo from my '96 the other day. It has 270k miles on it. 150K of those with a manual boost control set to 14PSI! It still worked great. No shaft play and the blades look good. I did have to replace the "blow off" valve diaphragm a few yeas back because it was torn and making weak boost. It has developed some oil leakage from the seals, but that can be remedied with a Mitsubishi rebuild
'00 S70, '04 S60 and the never ending quest for Stage Zero
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
rspi wrote:That did NOT damage the turbo, just blew oil through the piping.
Sure. I am not defending the dealership, just trying to explain to OP why the turbo might be in the conversation.
