Lol. Yes it's all Volvo.regent wrote:Yes, they do. (Let us pray we won't have to buy those too often though...)shiloh51933 wrote:... They also make Volvo transmissions.
I hope you've got a real INA idler and tensioner in there, too.
2004 XC70 Loose Exhaust cam gear
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- shiloh51933
When you say preload what kind load are u taking about?vtl wrote:2.5T engine has VVT hubs on both camshafts. At least one is bad, as you describe it.shiloh51933 wrote:My water pump is shot, what do u mean vvt hub, the exhaust pulley part of exhaust sprocket? How do ii align the sprockets with cam?
You need a camshaft lock tool to do VVT hub. It attaches to camshafts on the other side of engine and does not allow them to move. I recommend to read VVT hub replacement procedure as you need to do marks and and know how to preload hub the right way.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
It looks like you do not have the VVT Replacement Procedure, no?shiloh51933 wrote:...When you say preload what kind load are u taking about?
I have attached the one from VIDA, it will help you...
Have a safe and enjoyable weekend!
04XC70 VVT Replacement.pdf- (442.13 KiB) Downloaded 798 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- shiloh51933
Good look on the link for VVT hub procedure.regent wrote:It looks like you do not have the VVT Replacement Procedure, no?shiloh51933 wrote:...When you say preload what kind load are u taking about?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Consider replacing serpentine belt, tensioner, and pulley too. In the hoopla of timing belt these parts are often ignored. It operates mother of all systems.
- shiloh51933
Yes thank you, Serpentine belt is fairly new.xHeart wrote:Consider replacing serpentine belt, tensioner, and pulley too. In the hoopla of timing belt these parts are often ignored. It operates mother of all systems.
- shiloh51933
I understand the slots should be at 3 & 9 but should those little notches match on both cams? Meaning should both notches face upwards? The intake notch is at 2oclock and the exhaust notch is at 5 o'clock.
- shiloh51933
I ran out of light but there locked up.
- shiloh51933
I hope you've got a real INA idler and tensioner in there, too.[/quote]
- regent
Well, I say you've managed to produce sufficient amount of solid evidence, far beyond reasonable doubt. Very nice photos
Hope everything is going well
2015 BMW 335i
2015 BMW 335i
- 1520 Views
Last post by iRenaissanceMan
- 6555 Views
Last post by matthew1
- 23 Replies
- 2652 Views
- 4907 Views
Last post by Randdaddy
- 1704 Views
