Interesting bc I cleaned the TB in situ, did not even touch the electrical connector.
And it ran fine for a while. Will check it when I have time.
"Reduced Engine Power" Limp Mode Topic is solved
- Been thanked: 504 times
So I removed the Throttle Body and cleaned it again.
The connector seems fine...
The trick to avoid damaging the plastic connector...use a very small screwdriver and insert it in to push the plastic tabs away from TB. A small coffee stirrer is ok too.
Just remember the connector has 2 tabs, one on each side.
Then cleaned the connectors with a small spray of carb cleaner.
Cleared the codes mentioned above.
All is fine for now, but the causes of this event may never be found...
I just read the thread below.
Anyone here has plastic gear/potentiometer issue?
My 2006 S60 has only 102K miles, too early for these issues?
Anyway, mine was 1 time event...for now!
viewtopic.php?t=84468&sid=7ec9e09dbc801 ... 6&start=10
- 1158 Views
- 4306 Views
Last post by jonesg
- 59 Views
- 1981 Views
Last post by precopster
- 4180 Views
Last post by earthworm
