'95 T5-r Misfiring 3 way Cat Codes
warmblood58
- Year and Model: 1989 245
- Has thanked: 5 times
- Been thanked: 2 times
Thanks, yes, misfire goes away when I take foot off peddle and engine not under load. The good news is yesterday, I replaced fuel pump (old unit was Walbro) with a Bosch pump, replaced 15 year old wires with new Bougicard wires, recleaned throttle body and replaced turbo waste gate hose which was pretty cooked. I also pulled throttle bottle to clean more completely and checked EGR which was quite clean and unblocked. A few vac connections seemed loose so I improved their fit and also replaced vac tree o-ring. I now have a very fast car with no misfiring!!! If I had to guess, while all minor repairs helped and certainly increased fuel pressure should help, I would bet it was the wires that made the difference . . . always the simple things it seems. This car is a a beast!
warmblood58
Oh, I had also removed and cleaned idle air control valve and cleaned TPS electrical connector contacts. Quite often, I have found a light blue grease I believe in some of the connectors. At first, I thought this was blue/green corrosion but now I think it was either a factory installed electrical grease or PO had used soeme other product. Anyone encounter this? Thanks!
JDS60R
- Been thanked: 3 times
Great .
Guess the wires were not as new as they looked when you wrote your first post.
Dielectric silicone grease comes in many different colors although a clear to clear/white is most common. It tends to turn a brownish/clear with heat.
The green flaking substance is the common corrosion found if the connector is exposed to air or water over time.
So what is your fuel pressure now ?
What was the date on the wires?
Retired
warmblood58
this stuff is more like a blue green grease, either way, I cleaned liberally with electronic contact cleaner. Wires had a 01 date! Fuel pressure is now about 43psi -thanks again
- 12 Replies
- 4962 Views
Last post by brunocerous
- 12 Replies
- 2433 Views
- 9478 Views
Last post by volvolugnut
- 25 Replies
- 8893 Views
Last post by DavidsVolvo
- 20 Replies
- 4247 Views
Last post by undflyer
