Compare the wagons! P2 vs. P80
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
05 V70 8
96 855 2
2005 will not need: an evaporator, a whole lot of broken dash stuff repaired, RH airbag cover warpage repair, a new battery every 4 years.
Both will need spring seats and some front end bushings.
2005 is a better ride, quieter, colder a/c, better sound system and several other things improved or more modern.
2005 has less module failures (CEM in particular) comparted to 99-2004 P2 models.
96 855 2
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Catch can will not be helpful if oil ports are blocked.It can only help with blue smoke from exhaust.beigg wrote:Catch can and hose end caps. Probably be same or less cost in parts.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
This!jimmy57 wrote:05 V70
Ac suspension and interior noise im not concerned with.
I do like a firm reassuring suspension and very good heat.
What breaks apart 99-04 to 05+ ?
ugh smh 850 Turbo fridge
jimmy57
The P2 models had a major electrical change for 2005. Most relays dumped in favor of transistor power control, this allowed limiting bulbs to 13V for longer life. CEM and REM had complete renovations. Steering wheel module was revised. High speed CAN network (ABS, ECM, TCM [auto trans], DEM, and CEM) had comm speed increased to 500kbps from 250 kbps.
- 11 Replies
- 2843 Views
Last post by 1337
- 826 Views
Last post by sleddriver
- 1031 Views
Last post by RickHaleParker
- 178 Views
Last post by SonicAdventure
- 4446 Views
