FLXC90,
See my above post with the photo of piston head damage.
Odd Exhaust Valve Issue 1999 V70
- nickelghandi
- Year and Model: 1998 Volvo S70 GLT
- Has thanked: 14 times
- Been thanked: 3 times
-Nick
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Yeah-I edited my post, started to draft while you were loading last post I guess. I would blend it out and go for it!nickelghandi wrote: 21 Jul 2018, 14:33 FLXC90,
Current Volvos:
- nickelghandi
So you think just blending out the valve seat would bring it to drive-worthy condition? After finding this damage so late, I am inclined to check other cylinders now for evidence of damage. Maybe run some Sea Foam or water through to clean off some carbon and make it easier to see with my camera.
-Nick
- SuperHerman
- Been thanked: 207 times
As for now timing cover guide. Suggested work arounds work or just put engine at TDC based on crank and fashion your own marks based on lines you can repeat. Better yet - source a used one while you rebuild the top end. As the head is coming off you need not worry about much until you reassemble.
As to the engine. Don't bother cleaning anything until after the head is off. Just pull the head, file down the piston marks the best you can and fix the valve issue(s).
I think I asked earlier if it looked like the head gasket was changed - that will answer your question if they prior owner was in there.
You should be able to get it all done for under $300.00. Fresh top end and a $500 cruiser.
- 2180 Views
- 590 Views
Last post by Eddystone
- 17 Replies
- 931 Views
Last post by hausmeister
- 21 Replies
- 6601 Views
Last post by difflock54
- 990 Views
Last post by bmdubya1198
