Oil Changed - Serious questions
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
When changing to synthetic, I would keep a close look at the oil level. I'd check it no later than each week, even sooner at the beginning. My car drunk oil like crazy when I switched to synthetic, for the first 1-2 oil changes, then the level got stable back again
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
What is meant by wrench off?? You don't need a tool to remove it?WhatAmIDoing wrote: 21 Sep 2018, 16:45 You can get Mobil1 full synthetic at walmart for $4 a quart, so I really don't see the need to cheap out on oil. I buy Mann filters, but K&N also makes really good wrench-off oil filters, IMHO.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
viper69
What do you attribute that observation to?oragex wrote: 21 Sep 2018, 17:25 When changing to synthetic, I would keep a close look at the oil level. I'd check it no later than each week, even sooner at the beginning. My car drunk oil like crazy when I switched to synthetic, for the first 1-2 oil changes, then the level got stable back again
Volvo 850 GLT 1995
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Yes, They come with a hex nut molded into the bottom. Just use a large box-end wrench to remove (I don't remember the exact size in mm). Some also have rubber grips built in.viper69 wrote: 21 Sep 2018, 18:17What is meant by wrench off?? You don't need a tool to remove it?WhatAmIDoing wrote: 21 Sep 2018, 16:45 You can get Mobil1 full synthetic at walmart for $4 a quart, so I really don't see the need to cheap out on oil. I buy Mann filters, but K&N also makes really good wrench-off oil filters, IMHO.
If your seals are really worn out, I guess this could be true before the seal conditioners start to work. Another point, if your car leaks oil and you have been using conventional, consider switching to 10w-40 synthetic. Synthetic maintains it's viscosity much longer, while conventional oil tends to thicken up (leaks less the longer since your last oil change). So 10w-30 synthetic might leak more and not stop leaking.oragex wrote: 21 Sep 2018, 17:25 When changing to synthetic, I would keep a close look at the oil level. I'd check it no later than each week, even sooner at the beginning. My car drunk oil like crazy when I switched to synthetic, for the first 1-2 oil changes, then the level got stable back again
Also, another point to mention. Synthetic oil from a reputable brand general contains more detergents than conventional oil and does a better job at cleaning. You may want to shorten your change intervals to every 2,000 miles for the first 2 or 3 oil changes. Though it doesn't sound like you drive much, so I guess that doesn't really matter.
Knows enough to be dangerous
- 87 Replies
- 29662 Views
Last post by xydki
- 68 Replies
- 11352 Views
Last post by 1ezliving4ume
- 1546 Views
Last post by 93Regina
- 18 Replies
- 4311 Views
Last post by aaus3736
- 2286 Views
Last post by MoVolvos
