1998 V70 GLT Stops abruptly after new head
- Has thanked: 316 times
- Been thanked: 531 times
And I highly doubt the relay is the culprit. A dead fuel pump relay will usually result in a no-start.
- Has thanked: 311 times
- Been thanked: 817 times
As I was reminded this week, fuel pumps usually go no-start as well. They just die, they don't get weak.
dobrosailor
- Year and Model: 2002 Vovlo C70
- Has thanked: 5 times
I cannot help but think that the car is running in a open loop mode while cold then it shifts over to closed loop and doesn't get the data it needs to run in closed loop mode with sensors. I checked all the connectors, cleaned many - have a friend with a junk yard so I will pull an ignition switch, coil, cam sensor... anything else???
crank sensor
fuel pump but I doubt it
bmdubya1198 wrote: 09 Dec 2018, 08:07 And I highly doubt the relay is the culprit. A dead fuel pump relay will usually result in a no-start.
I think we have had 4-5 documented COLd weather intermittent run/ starts solved my fuel pump relays this fall??
Is that right? Interesting... I figured that was something that either worked or it didn't.abscate wrote: 09 Dec 2018, 09:46bmdubya1198 wrote: 09 Dec 2018, 08:07 And I highly doubt the relay is the culprit. A dead fuel pump relay will usually result in a no-start.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I had a KAE relay work fine cold, but as soon as the engine heated up it would misfire. Brand new Volvo relay fixed the issue. These things seem to defy logic.
Knows enough to be dangerous
My KAE relay failed completely after a few months. Always use an original Volvo relay!WhatAmIDoing wrote: 09 Dec 2018, 14:59 I had a KAE relay work fine cold, but as soon as the engine heated up it would misfire. Brand new Volvo relay fixed the issue. These things seem to defy logic.
KAE bad, bad bad bad bad.
dobrosailor
So I wenr another round yesterday. Car wouldnt start this time. Hooked a spark plug to the coil and sparks a little intermittently then no spark. Checked codes and sensors, when turning over it reads the RPMs so that means the crank sensor is working, right? Reads the correct temperature. I see lors of ECU issues on ‘99s and videos on how to remove theit ECUs but there isn’t one video or writeup on how to access a ‘98 with the strap across the top of the box. Just wanted to clean the connectors which makes me think there isn’t much issues with the 98 ECUs. Fair assumption? I jumper the fuel relay to no change. Thoughts?
- 202 Views
Last post by jreed
- 917 Views
- 1471 Views
Last post by chrism
- 11 Replies
- 2573 Views
- 2818 Views
Last post by NYVolvo1994
