I don't get it...it should do the opposite.
How accurate is your pressure gauge?
Try to prime the system few times...key in pos.II...wait 2 -3 seconds...back to pos.I and imediately again to pos.II...Do that 3-4 times and watch the pressure on gauge.
Volvo 850 power loss under hard acceleration Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Here we go again. How about you pack up the smugness and read what I wrote, which is exactly what you peppered with .......’s and rewrote.misha wrote: 29 Jan 2019, 06:48 Here we go again...![]()
Fpr is dictating what fuel pressure would be in the system...not the pump.
Fpr is vacuum controlled...that said....pressure varies as vacuum varies....Fuel pressure is not steady in all running conditions.
The pump WILL deliver 3 BAR because that’s what the pumps for these cars will deliver. If the pressure IN THE FUEL RAIL is different, then that’s NOT BEING CONTROLLED BY THE PUMP, or the pump has a fault. So pressure IN is going to be 3 bar, because that’s what the pump delivers. I never said it was static inside the fuel rail, but if the pump doesn’t deliver 3 bar, then something’s amiss.
Focus.....on.....reading...., and.... less.... on.... smileys...., .....misha.....
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- misha
Just to be clear here...
Are you saying that pump alone will make 3bar pressure?
If you simply put a pump in the jar or can with fuel and supply it with 12v source....and it will squirt the fuel with pressure of 3bar out of the feed line?
Is that what you're saying?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
The Bosch fuel pumps supplied for the 850 has an operating pressure of 300 KPA, with a flow rate of 120 liters per hour. System pressure should be delivered from 50-60% of rated voltage.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- misha
I didn't ask you that.
I know pretty good what spec they are.
Can you respond to my question please?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
I think I did - if you stick the pump inlet in a jar of fuel and turn it on, it'll spray out 120 liters of that fuel in an hour. So bring a big jar.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- misha
Read again...i asked you about pressure.Sommerfeldt wrote: 29 Jan 2019, 11:24 I think I did - if you stick the pump inlet in a jar of fuel and turn it on, it'll spray out 120 liters of that fuel in an hour. So bring a big jar.
- S
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 893 Views
Last post by Jaumme
- 1810 Views
Last post by jjlch
- 942 Views
Last post by Hardtofool
- 915 Views
Last post by bmdubya1198
- 4712 Views
Last post by June
