1999 S70 GLT Power Steering Foam - cause - missing return baffle in pump reservoir
Has thanked: 1610 times
Been thanked: 4071 times
From all data, which I believe comes from Volvo VIDA
1999 power steering Fluid Specification
(ATF) Type F, G, Dexron IID, E, III, Ford Mercon.
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
I have finally taken pictures of a disassembled 1999+ year PS reservoir. I just hacked it open so you will notice the rough edges at the seam between the upper and lower halves. The pictures have long titles to be self explanatory. I have added some comments to a few of the pictures.
Previous discussion in this thread made the point that a wire coat hanger can be used to grab the return tube and hold it in position and then use a channel lock style pliers to push the brass pipe back into the internal return tube. Of course you must first remove the upper hose to the PS reservoir. I replaced the factory clamp with a stainless steel screw clamp. This fix prevents you from having to buy a new reservoir.
I have not had any problems since I did the repair 3 years ago.
I think shrinking return hose allows brass pipe to work its way out of position.  Internal return tube then falls off.
Return tube is attached to upper half before assembly of PS reservoir by the factory
It hard to see but at the right angle of the return tube there is a solid plastic tip that presses against the wall of the reservoir.  The only way the tube fall off is the movement of the brass pipe our of position into the hose.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
