1999 S70NA Evita dome light 9483142 troubleshooting [Passenger door switch fault]
Already replaced with it a brand new one !!
- Has thanked: 311 times
- Been thanked: 817 times
It's never the ECU. It's always the overhead switch panel. Keep an eye on your hood springs.
Anyway oops my bad, two pages is a lot of posts to read, but why did you now mark it as solved?
I probably fat fingered it. I’ll check the ECU in the morning, or maybe it’s bad gas. Come to think of it, if I wash my old hood springs with bad gas, could that hurt the ECU?
Car is in VIDA hell getting keys made at moment, so not nearby.
Well, checking the green box myself mistake worked a miracle
I stopped in on the car and the dome light is working perfectly
Turns off 18 seconds afterward door closing
- RickHaleParker
- Been thanked: 977 times
Electrical connection on the fritz. Your fiddling with it push it toward the light.
Active
Past
Past
Hood spring now match damping of the rear hatch strut.
Proof is left as an exercise
...and it is back. Dome lights will not turn off with all doors closed.
Trunk lock is also not working correctly - AH-HA!!!!
I wonder if a lock not in correct place will mess up sleeping modules and inhibit VIDA from Programming mode.....Hmmmmmmmmmm
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Trunk lock has always been a b*&%^ on that car.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Having done the latch on my V70 I know what the problem is , it’s a simple repair on a complex System!
...and the S70 is completely different than the v70...
The V70 handle release is a mechanical plunger acting on the latch, the S70 is an electrical switch actuating the lock solenoid in parallel with the driver door switch
On a V70, pushing the button unlocks the tailgate, does not pop it
On the S70, the button pops the trunk up, via electrically
