2008 3.2 stalls/dies/won't start Topic is solved
- dandan
- Year and Model: 08 XC90, 21 XC60
- Has thanked: 19 times
- Been thanked: 8 times
I did give up and take it to a local independent volvo tech. Turns out I had the bad luck of installing a faulty fuel pump the last time. So I purchased another and it started right up after they installed it. This will be the 5th fuel pump in this vehicle
Current: 2008 XC90 3.2l AWD, 2021 XC60 2.0l Inscription Polestar
Past: 2000 S80 2.9l
Past: 2000 S80 2.9l
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Dan^2,
Five fuel pumps!!!!!!!!
That is true dedication.
You need to change your screen name from DanDan to XC90_Dan
Glad to hear that you got it fixed
Take care
Paul
Take care
Paul
- RickHaleParker
- Been thanked: 979 times
Five!
I would be looking for poor grounds that drop the voltage and up the current. The pumps need X amount of power to run. If the voltage drops the current must come up to get the required power.
Active
Past
Past
This is sparse data but the take home I get from these is that the
Electronic fuel pump parts >>>>>>> Mechanical parts reliability
It seems like time and time again we troubleshoot waveforms, PEMS. CEMS and then find a kinked line.
Guru jimmy has a great dirt add on in the shockwave thread about how you can go through 5 pumps getting the dirt out of the tank.
- dandan
First fuel pump was the stock pump. The first replacement pump I was unaware of until it fail. Upon replacing the pump I noticed that it had already been replaced. (So 1st pump replaced by me was the 3rd pump in the vehicle.)
3rd pump failed due to user error in installation (kinked line)
4th pump installed great worked for a week and failed.
5th pump replaced by independent shop. Still seems to be running fine!
All pumps installed after original were delphi pumps.
Past: 2000 S80 2.9l
Past: 2000 S80 2.9l
- 1251 Views
Last post by pkzip5
- 1274 Views
Last post by jenkinskg
- 872 Views
Last post by valarinz
- 13 Replies
- 5345 Views
Last post by volvolugnut
- 1060 Views
Last post by henri65
