Cam bearing wear, would you reassemble?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 1502 times
Been thanked: 3817 times
Re: Cam bearing wear, would you reassemble?
Lowe’s has 1/2 inch drive metric impact sockets down to 10 mm
highmiles
Year and Model: 2001 S60 T5
Been thanked: 4 times
Post by highmiles »
Blackbart- Cam swaps seem to be pretty widely done (turbo to N/A, vice versa, and variable to fixed head etc.) and I have not heard of any issues so the machining on these must be consistent. Can't quite wrap my head around why the line boring would not be either, in my case there were 2 apparent bearing areas that were damaged while the others looked OK. No damage on the cam, explained by the fact that the cam is steel vs. the aluminum head.
I suspect the sealant goes to about 0", but who knows how they figure it. There is an allowance for a layer of oil between the cam and bearing surface so the variability may be washed out in that.
Abscate- Correct, Lowes has a pretty good selection (now branded as Craftsman at my store,) and I did pick up a 14mm impact socket while I was getting replacements, however it was too wide to fit through the hole in the head to reach the bolt. YMMV with a different brand.
Thanks!
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Thanks for that cam info.
Yes, my experience with impacts is they're too thick-walled for tight clearance situations. However, if I'm using a 1/2" drive or breaker bar on a 13 or 14mm bolt head, I might have other issues to deal with!
highmiles
Post by highmiles »
Resurrecting this thread to provide an update and to say "thanks!" for the guidance.
After the machine shop did their thing, I reassembled the junkyard head using the valves and camshafts it came with, renewing the valve seals. Installed the head... etc. etc. and now how have a running and driving vehicle.
Getting familiar with my cloned VIDA-Dice device... already paid for itself... resetting the various codes that have appeared. Working towards keeping the MIL off so I can complete the inspection process and get a permanent license plate, giving it a good cleaning and prepping to sell. Have a manual shift S60 T5 lined up for the next project.
The biggest hurdle is a fairly large transmission leak... see separate post... that will need to be addressed pre-sale.
Thanks again, John
