The problem with that is, the active antenna can pickup a second RFID chip in the key being used and cause a no start condition.misha wrote: 22 May 2019, 08:55 Just open the steering wheel trim(the one around ignition lock)....place the key or chip around antenna or inside the trim itself...pack it back and you're done.
Will this work to bypass the chip keys?
- RickHaleParker
- Been thanked: 977 times
Active
Past
Past
- misha
- Has thanked: 155 times
- Been thanked: 432 times
He will need to cut new regular key(non-chipped key) and to extract the chip from old key or to place the old key around antenna.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
This is ALL you need to do...or to glue the old key around antenna or onto ignition lock trim.wrybread wrote: 21 May 2019, 19:37 I'm planning to open the chipped key to extract it's chip and glue it to the ignition so I can use non chipped keys, if anyone sees any problem with this approach please let me know.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
wrybread
- Has thanked: 15 times
- Been thanked: 15 times
Good point. I should say to anyone looking to do this, when you get keys cut, make sure they don't have chips in them. Or remove the chip if they have them, since other chips will make the car not start even if it also detects your good chip.he problem with that is, the active antenna can pickup a second RFID chip in the key being used and cause a no start condition.
The keys I got at my local locksmith didn't have chips so no biggie for me. Mine were $55 each but I'm seeing a wide range of prices mentioned online down to half that.
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
- RickHaleParker
Came across a possible third option. Key cloning for transponders that use the ID48 chip. Which is what Volvo uses. Just need to find a locksmith with a key cloner and find out if it is cost effective.
[youtube][/youtube]
[youtube][/youtube]
Active
Past
Past
wrybread
Interesting. Too bad about needing the car present for the process, otherwise someone could make a bunch of $$ with that doing cloning by mail.
FYI that key cloner is $1200 new - which is worth three key changes at dealer.
MVS loaner,,,,MVS loaner...drum beat...
Just two sets of USPS small box at $7 per
Still could - send key, send cloner back to customer, return clonerInteresting. Too bad about needing the car present for the process, otherwise someone could make a bunch of $$ with that doing cloning by mail.
wrybread
I can't imagine that process being cheap enough that it's preferrable to DIY types than just popping out a chip and doing this mod, but who knows. I can't imagine it losing money long term tho so I think you should do it!
- RickHaleParker
There are new units on eBay. Buy it now for $999.00. More than 10 available / 6 sold.abscate wrote: 22 May 2019, 13:44 FYI that key cloner is $1200 new - which is worth three key changes at dealer.
The loaner program would need like a $1500 deposit to make sure it comes back.
If we could extra M-Snope we might be able to get the cash layout down but the process would be longer.
Deposit on M-Snope and payment for Key blank + shipping.
Member sends Original key to Cloner
Cloner sends Original key + M-Snope to Member.
Member sends Original key + M-Snope to Cloner.
Cloner sends Original & Cloned key to Member.
Return deposit.
Active
Past
Past
- RickHaleParker
Another possibility is to have designated cloners around the country. When somebody needs a key cloned the cloneing equipment is sent to the nearest designated cloner then the member can go to them.
Active
Past
Past
