Engine died while driving and won't start. Topic is solved
valvolvo70
Year and Model: 1998 V70 T5 249K
Has thanked: 10 times
Been thanked: 8 times
Post by valvolvo70 »
I also checked to see if the fuel pump was running, it did. Fuel out of rail at valve. Also jumped the fuel pump relay, pump ran constantly. Going to check for spark tomorrow.
valvolvo70
RickHaleParker wrote: 29 Mar 2020, 17:00
valvolvo70 wrote: 29 Mar 2020, 16:56 My battery is dead now so I have to jump start.
You need to put the battery on a charger for at least a couple of days. Then take it to a parts store for a bench test.
3-4 times then "thud" is symptoms of a battery issue but it could be other things.
Battery is 4 years old but what gets me is that I was driving when everything stopped.
valvolvo70
UPDATE:
Haven't touched my T5 since Sunday. Checked for spark today, pulled plug #1 and grounded it on the block. Turn over the engine, see spark and it starts! Put plug back in, crank again, its starts! While idling, there's a noticeable "ticking" noise coming from the head/plug area. Shut it down and dropped it off the jack stand (just pass. front). Try to start again, only turns over, no start. Tried to repeat the first condition right down to aligning the timing marks, pulled plug #1, no start. Added 2 gal. of gas thinking the fuel gauge is bad, aligned timing marks, with #1 plug in, no start...
valvolvo70
valvolvo70 wrote: 01 Apr 2020, 15:42 UPDATE:
Just read this from another post...my situation exactly except the right side was jacked and a little low on oil. "Lifter ticking was mostly the result of having started the engine with one side of the car jacked up looking for exhaust leaks and having way too little oil in the crankcase."
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Low on fuel?
What fuel gauge is showing...where is the needle?
Put it back on that jack stand and try to start it again.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
valvolvo70
misha wrote: 01 Apr 2020, 18:04 Low on fuel?
I had over a 1/4 tank of gas before adding 2 gals.and I did put it back on the jack with no luck with starting again.
misha
Post by misha »
Time to check main fuel injection relay...grey one on fan shroud.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Did you try giving it a 3 -5 second shot of Starting Fluid and see if it fires on ether. If it fires or starts on either it is a Air/Fuel issue.
Active
Past
valvolvo70
RickHaleParker wrote: 02 Apr 2020, 12:50 Did you try giving it a 3 -5 second shot of Starting Fluid and see if it fires on ether. If it fires or starts on either it is a Air/Fuel issue.
I haven't yet Rick, thank you for the reminder. So do I spray SF past the MAF sensor? Or...
RickHaleParker
valvolvo70 wrote: 02 Apr 2020, 15:59 I haven't yet Rick, thank you for the reminder. So do I spray SF past the MAF sensor? Or...
Past the MAF. You want it deep so that you need not worry about backflash. Put a spray tube on on the can. Pull a vacuum hose somewhere along the air intake pass the MAF. Use the spray tube to inject the either.
Active
Past
