Volvo 850 engine stuttering at low RPM, not sure why?
Krisemann
Year and Model: 1994 850 2.5 144hp
Has thanked: 3 times
Re: Volvo 850 engine stuttering at low RPM, not sure why?
Post by Krisemann »
misha wrote: 27 May 2020, 14:23 What you mean by hand sanitizer?
It should be clean alcohol....without leaving residues.
Yeah, bought it at the drug store. I believe it's a combination of alcohol and isopropanol, but both should vapourize.
I think the metal casing comes off, will try.
'95 Volvo 854 2.5L 144hp 10v non-turbo, bought it in 2017 with about 280k km (174k miles) on it, is at 322k km (200k miles) as of May 26th 2020 - My first car, and I love it :D
Krisemann
Post by Krisemann »
And presto, out of its cover. The number is 876 4214.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Yep...that's the MAP!
http://www.bildelsbasen.se/?link=item&s ... d=24973327
This is how to test it:
Instead of vacuum pump,you can create a vacuum with your mouth and use the vacuum line side from the manifold.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Krisemann
Post by Krisemann »
I don't seem to be able to get any contact, I tried sticking a metal pin into it like shown in the pic but I don't get any readings. I suppose I need to find a longer metal wire somewhere, but I'll have to do that tomorrow, though I pushed it far enough in to the point where it hit something solid?
misha
Post by misha »
Key in pos.II?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Krisemann
Post by Krisemann »
misha wrote: 27 May 2020, 16:52Key in pos.II?
Yep, obviously :P
93ForMe
Year and Model: 1993 850
Has thanked: 6 times
Post by 93ForMe »
Krisemann wrote: 26 May 2020, 17:29 This is very common. From a cold start the car runs for a few minutes, then once the engine heats a little bit the stuttering begins. Usually happens at around 2000-3000rpm (so when I start from a complete stop or when I drive at a steady speed on the motorway).
Does the problem go away once the car is full up to temp after 20 minutes or so, or will it persist through a long drive?
Richard99
Year and Model: 2000 V70XC
Has thanked: 26 times
Been thanked: 22 times
Post by Richard99 »
Clean the air idle control valve.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
Krisemann
Post by Krisemann »
93ForMe wrote: 27 May 2020, 18:16 Does the problem go away once the car is full up to temp after 20 minutes or so, or will it persist through a long drive?
It used to work smoothly once the temperature stabilized, but this only happened if I let it idle (the engine refused to get to work temperature when I was driving, especially when the weather was cold). It also ran perfectly when the O2 sensor was plugged out, but now it's struggling even when the O2 sensor is disconnected (though less than when it's connected).
Richard99 wrote: 27 May 2020, 22:57 Clean the air idle control valve.
Hmm, idle is fine though, unless I plug in the O2 sensor. I'll look at it anyway :)
misha
Post by misha »
Did you checked IAT values with multimeter?
Once it checks ok....we will proceed to MAP.
If it is ok....we will attack FPR.
If all of that checks out ok....then your brand new o2 is bad(it happens) or you have a vacuum leak which needs to be fixed and which can affect ALL related sensors and fpr.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
