control arm bushes replacing without press Topic is solved
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Strong vibrations have also been reported even with only an upper engine torque mount in polyurethane. But assuming all engine mounts and subframe bushings are the standard rubber ones, I would not expect vibrations from the engine to be transmitted through polyurethane control arm bushings to the steering wheel (also assuming the wheels are properly balanced and the axle joints are in good condition).
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Had the car aligned today after replacing LCA mounts and new shocks, but driving back from the shop i am very impressed with the improved feel the car has. Ive read people saying its a night and day transformation, in my case not sure i would go that far but it is better.There are No vibrations felt through the steering wheel or car.
In regards to the upper mount, i felt some vibrations only at idle in my XC70 manual after fitting poly bushing but this was because my engine was rough, now ive done a tonne of work on the engine i can feel almost no vibrations at idle or driving.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- 1121 Views
Last post by Ou2mame
- 235 Views
- 15 Replies
- 3364 Views
- 23 Replies
- 5889 Views
Last post by bluesguys80
- 13329 Views
Last post by MarcM
