Interchangeable parts from v70 to 97 850 sedan? Topic is solved
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
abscate wrote: 08 Aug 2020, 03:31 I’ve forgotten the Colonial translation of “slam panel” Cookeh....
I do apologise, I tried my best to use the correct Americanisms. P/N 1372541 for the 850s, though oddly this brings up nothing on volvopartswebstore. It is the fibreglass panel at the front of the car that the hood latches into, the headlights, washer motors, and horn bolt into.
EDIT: Found it, after much searching. P/N: 9151585, superseded by 1372541 (1372542 for the option without holes/fasteners for the headlight wipers). I've still quite no idea what this would be referred to stateside though.
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
Can the door handles from the sv70 swap to the 850? The fiberglass handles are a concern with the prickles.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
They are interchangeable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Cookeh
Post by Cookeh »
Sure are, was one of the first things I did for mine. Not entirely interchangeable though, you wont be able to swap the door lock cylinders over.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
A slam panel would also be known as a core support, as in supports the radiator core., at least in the traditional vernacular.
Current Volvos:
Has thanked: 1613 times
Been thanked: 4078 times
Called a ‘ front section’ you Volvo. I fruitlessly searched for it in the Body section, but of course could find Cookeh 850 front section because....
He used a part number
Found it for the 1998 1999 2000 only
Part 9151650
I’m going to put the one I harvested into safe storage as it’s $600 new
CIK7
Post by CIK7 »
abscate wrote: 09 Aug 2020, 04:33 Found it for the 1998 1999 2000 only
Part 9151650
I bought mine for $20 from jy when I finally chose to replace mine.
I’m seeing fewer p80s in junkyards, residence time is under one month, and I’ve developed an allergy to 90F heat and junkyards.
It’s much more lucrative to bywhole cars, harvest parts at home while drinking lemonade, and cashing out $200 scrap metal at end.
My 1999 v70 part out got the attention of the IRS annuities division
CIK7
Post by CIK7 »
abscate wrote: 09 Aug 2020, 09:23 I’m seeing fewer p80s in junkyards, residence time is under one month, and I’ve developed an allergy to 90F heat and junkyards.
Yes I spent 4 hours one time without water and then 4 hours another time hydrated and both times, I came out SUPER dry throat. Of course at the end of the all-you-can-carry events, my heart felt like it was gonna pop.
I also agree about buying a whole car is better. I might do that on the side besides my SSI. Also I'm considering buying cheaper Volvos that need work done, do that work, then sell for profit.
