'03 s60 needs good engine shop
SantaFe75
Year and Model: 2003 s60
Has thanked: 16 times
Post by SantaFe75 »
abscate wrote: 24 Aug 2020, 18:26 Probably cracked head or just head gasket
You can’t move ECM units in Volvo’s after 1998
Ok, would my ecm work with any of the 2.5T Volvo's? My u-pull now has 5 2.5t's of various years. I've been searching
for the last two hours for an engine compatibility list, with no luck.
I can't afford to spend money on this engine rebuild and a replacement engine. If I had some certainty that my engine
only needs a gasket, great. On the other hand, if I knew that u-pull had an engine that would work that would be great too.
Thanks
SantaFe75
Post by SantaFe75 »
Well I did it. In my driveway. Yes, it was only a bad head gasket.
It looked pretty bad. The "leak" around #3 appeared to have been the worst but, 2 & 4 were a close second.
I feared the warpage had ruined the head. Luckily, when measured with a straight edge, it was only .22mm L & .08mm W.
Within spec but not great.
I used a plate and sandpaper to nudge the gap down to .05mm L & .00 W.
She's back together and running better than when I got her.
Thank you,
RobM
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
good job, any problems encountered ?
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
SantaFe75 wrote: 14 Oct 2020, 08:10 Well I did it. In my driveway. Yes, it was only a bad head gasket.
Thank you,
RobM
Thanks for sharing and posting photos. It's a big enough job by itself let along taking photos along the way; always appreciated this. Nice work.
Has thanked: 1610 times
Been thanked: 4065 times
Volvo horns awarded for removing 6 thou of warp with sandpaper!
That’s dedication !
Did you use new head bolts? That’s recommended by Volvo but I’ve always wondered if they are truly in the deformation limit
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
I’m getting ready to pull the head off my sons 04 s60. I’ve done 2 others. It’s 98. Do I need to align marks on the crank before pulling this apart like i did when doing the other two?
Thanks
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
stephansvolvo wrote: 14 Dec 2020, 12:45 I’m getting ready to pull the head off my sons 04 s60. I’ve done 2 others. It’s 98. Do I need to align marks on the crank before pulling this apart like i did when doing the other two?
Thanks
Yes, loosen the big crank nut first, then set crank and cams to the marks , before removing head
stephansvolvo
abscate wrote: 14 Dec 2020, 14:29
Thanks
That’s what I thought. I got the coil plugs and top cover removed then I thought I should check on this. Thank you.
Stephan
98 S70 GLT
73 IH Scout ii
If you have removed the timing belt you will have to juggle the cams and crank back to the marks individually. Don’t force anything. Don’t freak if the touch, you won’t damage them if you keep pressure light.
stephansvolvo
abscate wrote: 14 Dec 2020, 18:51 If you have removed the timing belt you will have to juggle the cams and crank back to the marks individually. Don’t force anything. Don’t freak if the touch, you won’t damage them if you keep pressure light.
I stopped before we went there. 😁
Stephan
98 S70 GLT
73 IH Scout ii
