I will double check the spark plug wires. Again
The video could be aliasing since the shutter speed and frame rate is comparable to DUT , for you electrical engineers out there
My S70 cranks with or without the clutch depressed...abscate wrote: 17 Aug 2020, 11:41 You guys with pre 1999 manuals, does the clutch switch inhibit cranking only like a 1999 or does inhibit ignition too!
you're talking about clutches; if you want to stop - its one pedal to the right...abscate wrote: 24 Aug 2020, 04:41 I wonder if Gestart Therapy will help Depressed Clutches
I just can’t stop myself, sometimes.
Well, they have a lot to be depressed about... less and less MT cars here in the US! And the "MT" that are being made are these clutchless pieces of crap!abscate wrote: 24 Aug 2020, 04:41 I wonder if Gestart Therapy will help Depressed Clutches
Confirmed wires are in positions, counterclockwise orderabscate wrote: 21 Aug 2020, 11:37I will double check the spark plug wires. Again
This is going to be on the morning agendavolvolugnut wrote: 25 Aug 2020, 12:45 Time to go old school. Pull No. 1 plug and turn crank to get top dead center. Pressure (or vacuum) the cylinder to confirm all valves are closed (ignition cycle position). Confirm the distributor is pointing to the No. 1 plug.
