Grinding noise, coolant leak, sudden death, and now won't start
- Been thanked: 4063 times
Head off and valve replacement is about 20 hours of Labour. Document where you lost compression so you remember which ones to replace! I think it’s only exhaust which contact, someone confirm please.
- befarrer
- Year and Model: 1998 V70 AWD
- Has thanked: 1 time
- Been thanked: 24 times
Remove the spark pliugs too, then when you are turning the crank over you dont have to worry about compression. Any resistance would be valves to piston, back crank off a bit, turn cams ahead, keep going until allignment marks are alligned. Dont force anything as its likely valve to piston contact.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- 23 Replies
- 4558 Views
Last post by MadeInJapan
- 2723 Views
- 966 Views
Last post by beigg
- 14 Replies
- 3074 Views
- 582 Views
Last post by yagger
