Massive Fuel Leak Need Help / Fuel Line Question 98 V70
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
98V70T5 wrote: 02 Jul 2021, 23:26 I found a mobile mechanic to come. Which kit should I buy? I don't know the size of the return line πŸ€·β€β™‚οΈ
Can 3/8" Oiteker clamps be used on 5/16"? Local store only stocks that size.
On my 850T5 the plastic line od is approx. 8.40mm; the exposed part of the barb seems to be .250" , but I can't remember if I could only find 5/16
Home Depot shows them on the website,
"1/4 in. x 1/4 in. Male to Male Barbed Coupler by Freeman"
(the link was obnoxiously huge)
I got mine at Autozone
foggydogg
Post by foggydogg »
All Stop, Matey !
I couldn't find the box with the leftover piece - naturally - so I put on some pants and drove to Autozone.
This is what you want.
Remember to warm up the line, and you will need to trim ca. 1/4" off to leave a little space for the center of the barb.
I didn't bother putting a rubber chafe guard back over it, I would rather see it in case it springs another leak.
I also culled some squirrels.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
:lol: I wonder if that warning is for the fitting or the packaging.
1999 V70 GLT
98V70T5
Year and Model: V70 T5 1998
Post by 98V70T5 »
Thank you soooo much foggydoggπŸΊπŸ‘! I will buy 5/16 barbs and line!
98V70T5
Post by 98V70T5 »
Chuck W wrote: 04 Jul 2021, 06:57 Just buy both to be sure. They're $6 each, and you should be able to return the one you don't need.
Wasn't too concerned about price/returns, but more with functionality. Didn't know if the return line was an odd size, other than 8 or 10mm, but it seems its been identified as 8 mm / 5/16". Both supply and return lines seem identical in size to my untrained eye.
Has thanked: 1609 times
Been thanked: 4064 times
Thanks for documenting , Foggy
If you go to Autozone, you don’t have to even wear pants
