When did you last have paid service for your Volvo
weitau
Year and Model: 2004 V70
Has thanked: 7 times
Been thanked: 2 times
Post by weitau »
Six weeks ago, I paid $600 labor to a home mechanic I know to replace the control arm bushings (had to press out the old ones), ball joints, replace all under engine motor mounts (except the rear engine). Bought the parts from Rock Auto.
My V70 had excessively loud engine noise, so took it into a muffler shop. They said it was the flex pipe. I agreed because they've done work for me before. $160 parts/labor/tip and 45 minutes later, no difference in noise levels. Learned my lesson. Trust but verify. Well, at least they found a rusted out hangar near the tail pipe and fixed it, and the total could have been a lot more expensive.
Old section of exhaust with flex pipe
Former location of section
Re-attaching the cat to the new downpipe/flex pipe.
2004 V70 2.4L
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Two jobs this summer I had done on our 02 S60 2.4t (190k miles) at our local independent shop, East University Imports in Des Moines.
First was a water pump failure. He pulled over quickly at the flow coolant warning and any coolant I added ran quickly out the timing belt area. Work was busy and had AAA tow straight to the shop. It was due for timing belt, had them do the cam seals too. $1141. Felt that was decent value for the work done, shop said it was close to losing the timing belt with how bad the water pump was so got lucky.
Second was a bit more irritating…two weeks later…same car, kid pulled a bit too close to the curb when parking at the mall and busted the radiator. Being plastic there is no repair so towed to same place again. $1020. Rad if I recall right was $600 which seemed high—but had work obligations that didn’t allow a lot of time to do the job.
Paid $1500 for the car at 150k miles five years ago, so still pretty cheap per mile with repairs I’ve done and paid to get done.
08 C702.5T (sold)
The non-Swedes:
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
wow i paid 600 for a radiator installed, part and labor.
had to do it again myself after lowering it on a jackstand that i forgot to move out of the way, part was less than 250.
Krons
Post by Krons »
jonesg wrote: 03 Jan 2024, 10:50 wow i paid 600 for a radiator installed, part and labor.
Oh, I forgot they also replaced the VVT solenoid with that job… so was probably closer to $800 for the radiator.
08 C702.5T (sold)
The non-Swedes:
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
In January of 2021 I got new tires mounted and balanced at a tire shop.
Has thanked: 1611 times
Been thanked: 4072 times
$10 nySI at Munch because my 1999s went emission exempt this year!
Yeah!
Has thanked: 2209 times
Been thanked: 1852 times
For the exhaust leak/load engine noise, check the cylinder head to exhaust manifold nuts are tight. They can loosen off.
manovlov
Has thanked: 674 times
Been thanked: 164 times
Post by manovlov »
To me, with all advices i get from MVS, Volvo dealer is a far memory...
I won't be able to thank you enough all for that !
