The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
- Has thanked: 317 times
- Been thanked: 531 times
The japanifold offers the best flow of them all.
- Has thanked: 987 times
- Been thanked: 1078 times
So japanifold is the performance alternative? Although the short length may not make much difference.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Yes. From what I've read there's also a difference in the internal runners as well as in the metallurgy to prevent that cracking.volvolugnut wrote: 02 Nov 2021, 12:01So japanifold is the performance alternative? Although the short length may not make much difference.
What I don't know is what years / models the japanifold was used. I don't think it was for long before they went to the " R ".
1999 V70 GLT
1999 V70 GLT
Correct. A buddy of mine over on Swedespeed (ScottishBrick) did a lot of work on this, including flow testing both the Japanifold and R manifolds. I don't remember if he ended up posting results, but I know the Japanifold is better overall.Sveedy wrote: 02 Nov 2021, 16:04 Yes. From what I've read there's also a difference in the internal runners as well as in the metallurgy to prevent that cracking.
It was used on 2001-2004 T5 and all 2.4T P2s. 2005+ turbos and all 2.5Ts had the "R" manifold.
- Has thanked: 1611 times
- Been thanked: 4075 times
Turbo control hoses still original, evaluate
Replace rusty clutch slave line
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Why is it a Japanifold? This is a Volvo stamped part made in Japan?
Bingo.BlackBart wrote: 03 Nov 2021, 09:32 Why is it a Japanifold? This is a Volvo stamped part made in Japan?
The R manifold was made in Japan as well, but the Japanifold came first, so that's where it got the name.
Got the turbo on.
Four mani to Turbo studs
Load coolant return stub hose onto coolant line
Load coolant supply stub hose onto line
Load turbo onto four mani studs, loose nut
SLip in coolant return stub
Slip on coolant supply stub
Clamp Oetiker clamps - need both end on and side on crimpers
Start oil supply line banjo
TIghten mani nuts
Tighten oil supply banjo
tighten coolant banjo.
Intall TCV lines
The tailagate is starting to be empty of project boxes.
TIghten mani nuts
Intall TCV lines
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
@Abscate - you're a machine!
Have a turn signal bulb I can't get into the socket, may stop over tomorrow if you're in the local area. Need a hand tomorrow by chance?
2023 Lexus RZ450e -66k
The list is getting shorter!
- 21 Replies
- 6030 Views
- 1682 Views
- 32 Replies
- 8493 Views
Last post by SoCalV70T5
- 28 Replies
- 5794 Views
- 12 Replies
- 1532 Views
