Vida CEM swapping
matija0610
Year and Model: 2003 S60 D5
Has thanked: 21 times
Been thanked: 13 times
Post by matija0610 »
ZRimaZ wrote: 22 Sep 2022, 09:52 Just change 0x8106 to 0x01 (max speed 250kmh) and recalculate chechsum at 0x8101
hey Z :) , it looks like I was looking for the wrong CEM when I wrote the instructions.. I'm reading superficially. :D
but I think we helped him.
@pontus, if it gets stuck, let me know. you will send me the .bin (PM), and I will show you on your example
ZRimaZ
Year and Model: XC60 MY2016 3.0 T6
Has thanked: 23 times
Post by ZRimaZ »
@Matija, are you sure? I think it is p2 car (cem brick)... Config starts @0x8100
Have a nice day,
ZRimaZ
PontusLSE
Year and Model: V70 2007
Post by PontusLSE »
Thanks for your input. I guess I am getting closer, but still not there yet. What I am trying to do is to limit the speed to 30km/h (Swedish rules that allows a 15yo to drive a car with certain limitations)
ZRimaZ
Post by ZRimaZ »
PontusLSE wrote: 22 Sep 2022, 11:14 Thanks for your input. I guess I am getting closer, but still not there yet. What I am trying to do is to limit the speed to 30km/h (Swedish rules that allows a 15yo to drive a car with certain limitations)
No way. There's no such a speed limit in this car :(
Have a nice day,
ZRimaZ
prometey1982
Year and Model: 2010 XC90
Been thanked: 5 times
Post by prometey1982 »
PontusLSE wrote: 22 Sep 2022, 09:45 I am trying to figure out how to change the maximum speed (v-max?). This ECU is modified from before, so my idea was to use vdash to set the max speed and after that compare the bin with the change to the bin without the change, to figure out what parameters has changed.
Speed limit map is inside ECM flash. CEM sends map index but values is taken from the map. So you can just change map's vlaues to FFFF (512 km/h) and speed limiter will be disabled.
Они просто сдохнут, а мы попадем в рай.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
ZRimaZ wrote: 22 Sep 2022, 11:16 No way. There's no such a speed limit in this car :(
Pull plugs from two ignition coils. Drop the (automatic) transmission into a limp mode. Install additional fixed blade throttle plate =) By the time a 15 y.o. reaches the top speed of 30 km/h he'd loose all the interest in cars.
ZRimaZ
Post by ZRimaZ »
vtl wrote: 22 Sep 2022, 11:22
Sorry, I forgot about this lifehack... :)
Have a nice day,
ZRimaZ
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
No
Swedish rules that allows a 15 year old to drive a Tractor not a car.
What you trying to build is called an A-traktor.
Google "Swedish A-traktor" see what your getting into before you proceed.
Swedish EPA rules
Must have a frame based chassis
Rear axle must be mounted directly to the frame without any suspension
The gearing must never let the rear wheels turn faster that 1/10th of the crankshaft
The wheelbase must not be longer than 2,25 metres
Must have a trailer hitch
A-Tractor rules
Must be based on a standard vehicle
The original car must have a curb weight of at least 2.000kg before modification
Cars under 2.000 kgs can be modified, but must be built as an open pickup, and be able to pull a 1.000kg trailer
Must be modified so that there is no space for transporting people or goods behind the front seats
Must have a reflective tractor triangle mounted on the back
Must be restricted to a top speed of 30 km/h by disabling gears and/or mounting gearing
Must be modified so the engine can’t run at higher revs
Frame and body must be original
The top speed was not limited (besides the 10:1 gearing rule), but the speed limit is 30 km/h, as with any other tractor in Sweden.
Active
Past
Divxet
Year and Model: 2003 v70n
Has thanked: 15 times
Been thanked: 3 times
Post by Divxet »
Is there anyone who can help me with the understanding/knowledge how to obtain information to fill in the list of parameters for T5Luke's program to change the configuration in the car's cem, I would like to contribute with my free time to complete the parameter list. I have Vida and Dice if that helps.
vtl
Post by vtl »
Divxet wrote: 23 Sep 2022, 07:10 Is there anyone who can help me with the understanding/knowledge how to obtain information to fill in the list of parameters for T5Luke's program to change the configuration in the car's cem, I would like to contribute with my free time to complete the parameter list. I have Vida and Dice if that helps.
Can pull everything from MS-SQL database that comes with VIDA:
Screenshot at 2022-09-23 09-49-59.png (38.63 KiB) Viewed 1092 times
More than likely, need to run a much complex SQL query to carve out data for particular model/year.
