Furthering on with the wiring changing to 30awg on the transmission lines.
It remains to be seen If it works. , I haven't checked the other cem but it's worth ago once again. Just encase
Vida CEM swapping
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
oscilloscope
oscilloscope wrote: 22 Oct 2022, 17:10 Furthering on with the wiring changing to 30awg on the transmission lines.
Something very odd happened lastnight during testing, I had it all connected up with the alternative wires , but tiredness prevailed, and I didn't switch on the power supply. But the cem cracker was working away as if it was on and reckoned it was working through the cem.
- RickHaleParker
- Been thanked: 978 times
Look at the schematic. The transceivers are connected to the USB 5V. It powering off the USB. You don't need an external power supply for just CAN Bus. K-Line would be a different story but the CEM-B is still uncrackable and we found a way around the K-line if anybody does ever come up with a crack that works on the CEM-B.oscilloscope wrote: 22 Oct 2022, 23:56 But the cem cracker was working away as if it was on and reckoned it was working through the cem.
Active
Past
Past
oscilloscope
That's fine , I wasn't sure what vtl ment if there was something else I was suppose to use. , I have indeed powered the transceiver modules i have with the teensy.RickHaleParker wrote: 23 Oct 2022, 06:07Look at the schematic. The transceivers are connected to the USB 5V. It powering off the USB. You don't need an external power supply for just CAN Bus. K-Line would be a different story but the CEM-B is still uncrackable and we found a way around the K-line if anybody does ever come up with a crack that works on the CEM-B.oscilloscope wrote: 22 Oct 2022, 23:56 But the cem cracker was working away as if it was on and reckoned it was working through the cem.
Which one is the cem-b The brick style one ?
oscilloscope
Excellent
The £20 quid cem was able to be cracked. , my next task to see If it works in IOT terminal
oscilloscope
Do you mean via an open source obdii reader where the k-line source code is freely available?RickHaleParker wrote: 23 Oct 2022, 06:07Look at the schematic. The transceivers are connected to the USB 5V. It powering off the USB. You don't need an external power supply for just CAN Bus. K-Line would be a different story but the CEM-B is still uncrackable and we found a way around the K-line if anybody does ever come up with a crack that works on the CEM-B.oscilloscope wrote: 22 Oct 2022, 23:56 But the cem cracker was working away as if it was on and reckoned it was working through the cem.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
You can connect to CAN via REM, etc, where k-line keep alive is not necessary.
BTW, the cracker supports k-line, just needs a chip and a couple of resistors. Mine has it.
oscilloscope
Would that mean it can support the older brick style cem ? With the correct supporting ic and Resistors?vtl wrote: 25 Oct 2022, 16:16 You can connect to CAN via REM, etc, where k-line keep alive is not necessary.
- RickHaleParker
Yep ... 1998 - 2004 P2. I could not come with a official name for it so I named it CEM-Brick.
Active
Past
Past
- 8963 Views
Last post by RickHaleParker
- 8783 Views
- 27 Replies
- 27582 Views
Last post by cn90
- 10186 Views
Last post by jonesg
- 5406 Views
