Has thanked: 1611 times
Been thanked: 4075 times
Adjusted parking brake, five clicks to get it tight how I like it. Holding on Evans driveway is my test
Sorted out my Volvo fasteners into Talenti jars
Documented the most meaningless part change from 1998 to 1999
:D
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
abscate wrote: 06 Oct 2019, 04:28 Adjusted parking brake, five clicks to get it tight how I like it. Holding on Evans driveway is my test
:D
Can't have too many fasteners!👍I bought some nice, not too expensive, Husky transparent organizers where I keep my nuts&bolts. I sometimes go to the junk yard just to buy fasteners! But I'm not right in the head 🤪
BMW 540i 2002
S70 Base 2000
jmcguire
Year and Model: 1996 850 Sedan
Has thanked: 19 times
Been thanked: 9 times
Post by jmcguire »
Swapped out the beige speaker covers with the gray from the donor car I took the carpet out of. I’m liking the contrast of the gray and beige interior.
1996 850 Sedan
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Looks really good!
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
I installed the repaired fuel tank - not too heavy but a lot of jiggling and wiggling around to get everything aligned right. Then got that rubber boot through the body shell and attached. Replaced a cracked vent hose. Ready to fill up.
Re-remembered how all the rear floor bits bolt back together, and the original unused third seat!
Managed to get that fourth vac line snaked through and connected - turbo housing to EGR valve. Did the other three turbo control lines a while ago and forgot this one - or avoided facing it. But not so bad really. Good light and a long needle nose pliers, and move some turbo hoses out of the way. (Note: The little squeeze clamps that come with the ipd silicone hoses will be too loose - use the old ones from your old rubber hoses)
Came out intact.....but with cracks at the bends. Was it from me yanking on it with a pliers, or already cracked?...hmm. I had an "EGR Flow Too Low" code for forever, could this be it? I've tested EGR, cleaned it, checked the intake port etc etc. We'll see if this solves it.
Then I used the Robert DIY to find my actual mileage on the computer before I replace the ODO gears.....178,000 mi, hmm. I would have guessed 160 or 165, oh well.
jmcguire
Post by jmcguire »
Went back to the pick a part yard and pulled the exhaust from the ‘97 850. A very well spent $27 I think!
1996 850 Sedan
kallekula
Post by kallekula »
jmcguire wrote: 08 Oct 2019, 13:58 Went back to the pick a part yard and pulled the exhaust from the ‘97 850. A very well spent $27 I think!
It looks like the pipe is smooshed just before the muffler?
BMW 540i 2002
S70 Base 2000
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
My S80 got hit :cry: ! Luckily it is just a fender and some paint work. Obviously Volvo built it tough. The Honda that hit me looked bad. So bad I was afraid to get out and look. I was expecting much more damage. I still feel sick... All day I have been driving my daughter's 2007 C70 and officially hate it! I sure hope my car is fixed fast. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
bmdubya1198
Fortunately that doesn't look too bad at all. You definitely have to love how well these are built!
I hope they put the best body person on that job, cause if it isn’t perfect June will let them know.
I also hope he checks his pockets for screwdrivers.
