S70 fuel economy or lack of it...
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: S70 fuel economy or lack of it...
Post by jblackburn »
Probably just the belt; the water pump should be fine upwards of 100K+. Check for any shaft play in the pump just to make sure.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Your car is going to use the mechanical tensioner; that needs to be changed as well.
'98 S70 T5
elchopperfreak
Year and Model: S70 T5 1999
Post by elchopperfreak »
I also have some questions about the 850, but Ill open a new thread..
Mostly a/c and a blinking arrow
elchopperfreak
On the Spring seats, read that the ones I need are from an XC 90, are the OEM the ones to purchase or KYB or Moog on ebay a good replacement? If the OEM is the way to go, can anyone provide a part number??
Are they upper and lower?
Thanks again
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Go with either OEM or the heavy-duty versions from IPD.
This is one of those sensitive spots where aftermarket parts wear out very quickly.
5 others that came and went
elchopperfreak
So, sachs/boge it is??
Any year XC 90??
Thanks
elchopperfreak
Found a number 30683637 for the spring seats
Checked in FCP Grouton and they have OEm for the s-70 but aftermarket for the XC90..
Will check IPD
kcodyjr
Post by kcodyjr »
Why wouldn't you get the OE S70 part, since you have an S70?
elchopperfreak
Read here in the forum that the XC90 part is much better, since its heavy duty.
kcodyjr
Post by kcodyjr »
I'd go for the brand-new HD ones from IPD, for an S70.
I'd still pick the OE for the S70 over an aftermarket or used for the XC90.
