S90 2 years of shifting problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
vova
Year and Model: s90 1998
Re: S90 2 years of shifting problem
Post by vova »
well said, i ll check lines and all related parts hopefully coming weekend.
thanks
i ll let you know once i get things checked out
vova
Post by vova »
Didnt have time to examin evap vacuum lines yet but at this point can confirm that problem starts once car is warmed up which is aprx. 10 minutes driving from a cold start. Drives fine when it is cold until it reaches operating temperature and above 20 mph. Also rmp doesn't tank with a feeling of shifting down and back up when floor the gas pedal.
When gradually accelerating warmed up car rpm tanks kinda going to lower gear briefly and right back up but Never stalls all this happen until car reaches speed of aprx20 mph, drives fine at speeds above.
one of these weekends will check vacuum evap lines as advised.
Should it change anything if i disconnect vaccum line of purge valve and plug off the hose?
