1999 V70 T5 M56 ELIZABETH 578465 Nautic Blue 417 Perfo 16 Wheels
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
Oil change M1 10W-30 197800
Recharged AC with 680g R134A at ambient of 60F
New pass wiper blade, retightened driver wiper arm
Tailgate latch replacement due to failed plastic internally
viewtopic.php?f=1&t=84018
Finally got around to replacing rear ABS harnessabscate wrote: 04 Feb 2017, 04:43 Replaced radiator with Nissens jan 15, 185000 miles
ABS still faulting on right rear wheel - ordered new rear harness from FCP
Thread here
viewtopic.php?f=1&t=84246&p=461773#p461773
Mileage 199716
Also flushed PS and replaced with Pentosin
view-topic.php?f=1&t=78410&p=461886&hil ... in#p461886
Replaced front right ABS sensor. Sometime I had repaired this from a break between the straun relief
Used a Delphi from FCP, fit perfect
M6 to release sensor from hub
Two attaches and two clips to harness
Cleared P1550 and spurious P0137
ABS light cleared in self test
Mileage 200,937
Mileage 200,937
Swapped in parts car driver seat skins for lower and upper seat part. Used nice skins from passenger seat of parts V70. Zip tied to stays. Applied leather conditioner. Also replaced seat bottom foam and heater
viewtopic.php?f=1&t=84734&p=466785#p466785
Replaced Cabin air filter
R/R Evap vacuum system, found bad hose - root cause of occasional rough cold idle - thread here
viewtopic.php?f=1&t=84552
Added 1 liter oil, 2500 miles down a 203,000
Rerouted CBV pulloff vacuum hose.
Replaced last Purge valve hose from check valve to snorkel with 3/8 fuel hose - needed clamp on nipple.
Checked and adjusted turbo waste gate valve - one full turn CCW, out for 4.3psi at WGA
Mileage 204,000
Mileage 204,000
Oil and filter change at 206400
Replaced lower intercooler hose and clamps..tough job due to limited space
Replaced oil cooler seals
viewtopic.php?f=1&t=83718
Replaced purge canister J hose and canister shutoff hose, tested canister shutoff valve
viewtopic.php?f=1&t=85260&p=471493#p471493
About one hour. Tight clearance for Oetiker clamp tool working under there
Silicon Spray sunroof guides
Tested AC on 90F day - awesome cold.
NYSI passed with no codes, all MON READY
