1999 V70 First timing belt install-mechanical tensioner
paredown
Year and Model: 1999 V70
Been thanked: 2 times
Post by paredown »
abscate wrote:Congratulations on your work...saving both your pocketbook and the environment. Keeping an old car on the road is greener than 5 Prii.
Thanks--and it builds character, too--or so I'm told. :lol:
1999 na 2.4l V70 beater--donated to Habitat in running condition
beoutside
Year and Model: 1999 xc v70 awd
Post by beoutside »
Just in case you are missing this step.... I always have to relieve the tension-er tension by using my long L allen 6mm wrench to apply pressure against the tension-er when installing the belt.
Thus the tension-er is on but not tightened down, the belt is routed properly around everything except the last pulley making sure there is no slack under the crank or extra belt teeth..... then use the allen wrench to release all tension, you have to hold this in that position and then the belt should just have enough clearance to just slide over the last pulley.
Then go back and set the tension properly and torque the tension-er bolt , with the spark plugs out I then hand crank the motor a few times check my timing marks and belt tension-er tension. Something always needs readjusting :)
1999 V70 x/c AWD
Go Forth and Seek the depths
that create spark in your life......
Or something along those lines :)
