04 XC70 Could it be the fuel pump?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mikeamondo
Year and Model: 04 XC70 - son's car
Re: 04 XC70 Could it be the fuel pump?
Post by mikeamondo »
Thanks for all your help over the last couple days. I had hoped to dig into the car more while here, obviously, but there was much to do in very little time.
The plan is to run the current tank down to see if the problem reoccurs. My bet is that it does. The seller (a private individual) had a full tank of gas in when Andy test drove the car, and oddly enough had refilled it when he picked it up. I think it's likely he knew about the issue.
Once the problem reoccurs, he will check the pressure again at the rail, both before and after opening the tank. And then another fill up to see if that again fixes the issue. And that, hopefully will show a little more about the problem.
By the way... is there a way to hook up the fuel pressure gauge without spraying fuel all over the place? Thanks!
Has thanked: 1504 times
Been thanked: 3817 times
You can relieve the pressure into a small rag with a screwdriver by depressing the valve center before connecting. Have you guys evaluated the fuel pump relay and circuitry to the fuel pump? Perhaps trying jumping it next time the issue returns?
mikeamondo
So.... for those of you who were following and helping in this saga. I assumed the problem would reoccur once the full tank of gas was run out of the car.... it did not. As of yesterday, he has burned out a full tank and it was showing 50 miles to empty and no problems whatsoever. She's starting and running like a champ. So.... could it just have been bad gas?
Bad gas is always suspected when cars don't run, but it never ever is bad gas. It's like the Lupus of car diagnosis. Nothing? No fans of "House" out there? Oh well....
If the issue does not reoccur, I suppose he's good to go.... but could bad gas cause a vapor lock issue like we saw? Opening the fuel tank allowed the car to start immediately.
I agree the "bad gas" diagnosis is used in place. Of IDHAFC what us wrong with your car. In medicine , they tell you your symptoms are "idiopathic" so they can charge you for the diagnosis.
I think opening the fuel tank was coincidental to starting. I don't think your car "vapor locked" in the classical sense.
But that's just one more idiots opinion....
mikeamondo
Not just an opinion.... pretty much how the world works these days.... cash is king.
So he finished out the tank of gas without any problems reoccurring. After he filled the tank, he observed and erratic idle.... a bit of revving prior to driving, but no dash warnings. Problem disappeared after he drove.
So.... unless that little clue means something, I'm going to park this thread, and only continue it should things go awry again.
Thanks for all the help!
hansenjg
Year and Model: 2011 XC60 3.2
Post by hansenjg »
My final thought is the same as my previous thought. Fuel filter. Worth a change, don't you think?
John
2004 C70 Ragtop w/2.4L LPT 65K miles (wife dd)
2003 XC 70 with 2.5L Turbo, 195K miles (my dd)
Parts Car: 2000 C70 Ragtop w/2.3L Turbo, died at 200K miles (water pump siezed. took out timing belt)
Not if pressure tests at spec. Pointless. Bad gas can happen, but it is much more urban legend than a common failure. In the 1970s when I was dating, bad gas was much more common.
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
True, but the fuel filter should have been replaced anyway at some point for a car this age... Part of regular maintenance.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
turbotim2
Post by turbotim2 »
I would pull the fuel pump and inspect the wiring and screen. I had one where I thought the pump had failed, pulled it and found the wiring in the tank had burned up. I am surprised the car had not exploded as the wire insulation had burned right off the copper core.
If opening the tank immediately solves your problem, that would indicate improper tank venting and may be causing some of your symptoms.
Change the filter, its easy and cheap.
mikeamondo wrote:Think I may be infected with Vovo Fever...
Don't worry, the constant repairs will cure you of this.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
