The WP was the source of noise, the bearing was shot making it difficult to spin. The tensioner/idler were both fine but I've replaced since I'm in there anyway. FCP had a decent deal on the factory timing belt kit and there shipping is always quick.regent wrote:Well, I say you've managed to produce sufficient amount of solid evidence, far beyond reasonable doubt. Very nice photos
Hope everything is going well
2004 XC70 Loose Exhaust cam gear
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Glad you sorted that one out.
And now that you've already paid, it's time to play
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- shiloh51933
Still not time to play I installed everything, the timing marks all match on cam sprockets and crank shaft but I got miss, I believe it's the tensioner. It was way too loose but the I'm getting misinformation about where to set it. The book said 7 o'clock but that seems too tight. I didn't want to go any further since it gets dark around 4-4:30 these days..regent wrote:Glad you sorted that one out.
- shiloh51933
Finally got tensioner process right but crankshaft moved out of alignment, I should have learned by now to stop working in the dark!!
- regent
WE would like to believe that your job assignment in the dark did not involve the use of a set of picks
List of Acronyms Used:
WE = A Group of Concerned Citizens
2015 BMW 335i
2015 BMW 335i
- shiloh51933
Do you means pictures?regent wrote:WE would like to believe that your job assignment in the dark did not involve the use of a set of picks![]()
No pics, my android doesn't have a flash anyway.
Tensioner was off and the crankshaft alignment moved/skipped, resetting crankshaft alignment.
- shiloh51933
Here's pics, as u can see all marks look good, crank mark hard to see but the rib behind CS pulley is pointing at marker, it sits between the two teethregent wrote:WE would like to believe that your job assignment in the dark did not involve the use of a set of picks![]()
- regent
No, what I meant was picks that you use to pick the locks when you work in the darkshiloh51933 wrote:...
Do you means pictures?...
Nice pictures though, I bet she'll be purring like a kitten now
2015 BMW 335i
2015 BMW 335i
- shiloh51933
I don't get the picks thing unless u mean like 60 seconds and gone.regent wrote:No, what I meant was picks that you use to pick the locks when you work in the darkshiloh51933 wrote:...
Do you means pictures?...![]()
As far as the timing marks if there in the right place it should purr like a kitten but there's a multiple miss.
- regent
Any codes?
2015 BMW 335i
2015 BMW 335i
- 1520 Views
Last post by iRenaissanceMan
- 6555 Views
Last post by matthew1
- 23 Replies
- 2652 Views
- 4907 Views
Last post by Randdaddy
- 1704 Views
