Rebuilt Calipers - Pins, What's the issue? 30648017
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Next time I check my pins I'm going to clean them up and spray them with silicone lubricant. It works great on all rubber parts and has no viscosity at all or temperature sensitivity.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
This is making me go look at my Kawasaki manual for my bike... I am betting that those are installed dry as well.JimBee wrote: 03 Oct 2019, 20:50 Next time I check my pins I'm going to clean them up and spray them with silicone lubricant. It works great on all rubber parts and has no viscosity at all or temperature sensitivity.
- Has thanked: 311 times
- Been thanked: 817 times
Let us know ... aerosol silicone I am speculating will have no longevity in this setting. Would be great to get monitoring info.wizechatmgr wrote: 04 Oct 2019, 20:59This is making me go look at my Kawasaki manual for my bike... I am betting that those are installed dry as well.JimBee wrote: 03 Oct 2019, 20:50 Next time I check my pins I'm going to clean them up and spray them with silicone lubricant. It works great on all rubber parts and has no viscosity at all or temperature sensitivity.
PeteB
- Has thanked: 57 times
- Been thanked: 11 times
I saved the OEM pins when I replaced them and I used ATE brake grease that I think I
found on sale at FCP one time. I've had so many freeze up over the years that I try to
use the correct type and I don't put too much on, just enough.
I thought the pins on the rebuilds just didn't look right - cheap.
- wizechatmgr
Checked the manual, they don't go in dry but I have to say I never lube them as long as they're in good condition. On the car they rust real quick. I think @Abscate and I two months ago had them out. When I was doing my spring seat the other day it didn't exactly look great. Might be time to spend the $$$ on the good OEM caliper pins.erikv11 wrote: 05 Oct 2019, 13:40Let us know ... aerosol silicone I am speculating will have no longevity in this setting. Would be great to get monitoring info.wizechatmgr wrote: 04 Oct 2019, 20:59This is making me go look at my Kawasaki manual for my bike... I am betting that those are installed dry as well.JimBee wrote: 03 Oct 2019, 20:50 Next time I check my pins I'm going to clean them up and spray them with silicone lubricant. It works great on all rubber parts and has no viscosity at all or temperature sensitivity.![]()
- Been thanked: 4068 times
Someone invented the work “silver cheese” which is a perfect description of cheap partsPeteB wrote: 05 Oct 2019, 16:51 I saved the OEM pins when I replaced them and I used ATE brake grease that I think I
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Agreed with PeteB's suggestion above. I've been using that ATE brake grease for about 8 years on the pins and backs of the pads and it has worked well in my situation (relatively rust free North Carolina weather).
- 15 Replies
- 6524 Views
Last post by wizechatmgr
- 17 Replies
- 2641 Views
- 13 Replies
- 1815 Views
Last post by foggydogg
- 1642 Views
Last post by pedal2metal
- 329 Views
Last post by rcbooth
