Tightened bolts on valve cover then check engine light came on..?
- Has thanked: 316 times
- Been thanked: 531 times
+1, gotta be your heater core. Do you smell antifreeze?
- Has thanked: 2200 times
OP mentioned he is NOT losing water (I'm assuming coolant).
Gin, when you say the floor is wet, is it all of the floor, the front mainly, the RH front, LH front, the rear?
If you are 100% you are not losing coolant, then it is not your heater core. When the heater core starts to fail, you get a sickly sweet smell, often accompanied by a greasy feeling to the inside of the windshield. The carpet is usually much wetter under the carpet than above. Please check.
Do you have a sunroof (moonroof) in your car?
The area you are getting the wetness on the floor is important.
If you can give us some more accurate details, it may help us to give suggestions where and what to check for.
- 2310 Views
Last post by oragex
- 964 Views
Last post by fixer333
- 1131 Views
- 1211 Views
Last post by precopster
- 2758 Views
