Timing belt tensioner shake
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Year and Model: 2004 V70 2.5T
Been thanked: 468 times
Re: Timing belt tensioner shake
Post by cn90 »
I personally think 1-2 mm movement during operation is probably normal.
The problem is: most of us do NOT look at the tensioner movement BEFORE the timing belt job.
We only look at it AFTER we replace the TB and tensioner just to be sure that it is properly installed.
Maybe out of 100 engines from factory, some tensioners move a bit here and there and is considered normal.
The question is: how much movement is considered normal.
If the P.O. did not have any issues with the engine prior to the TB job, and now he installed a Volvo OEM TB
kit properly, then I think there is nothing to worry about. Time to move on.
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Thanks guys,
Right, i should have look at the old tensioner before.
I went to the dealer this morning and asked about the slight move on the TB tensioner.
The technician told me that a little move on the tensioner is allowed and normal as it compensate the imbalance of other parts. But they do not like to leave it be for too long.
There is mainly two things which possibly cause shake on the TB tensioner to look at on the accessory belt. Check if the alternator pulley do not have play and if the pulley on the accessory belt tensioner do not have play as well. (My alternator is new)
The Tech told me it is better to change during the second timing belt the accessory belt and the tensioner to avoid any problems.
I did not changed the AB during the Timing belt change , but i did had a look at the pulley on the accessory belt tensioner which have a slight play and i could hear a bad bearing.
Ordered the accessory belt tensioner and the V-belt and the problem will be solved, i hope.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I remember a discussion, a member was also using a genuine (Ina) part, it was shaking. Then he replaced with a Gates part, no longer shaking (if my memory is still good 8) )
So may be related with the tensioner brand. I would say, chances are not to be worried, especially since this is a new tensioner. You can do a belt test - push in between the cam pulleys, see if the needle moves to the right and goes back smoothly when the belt is released.
Also notice how is the tensioner installed with the eccentric center piece that can rotate
Indeed, worth testing all pulleys on the acc belt - alternator (clutch type tested with a screw driver), ac compressor, tensioner, roller
Post by cn90 »
I think it is the other way around.
The problem was Gates and INA solved it.
