Well, it doesn't quite work like that, misha. You need a system. Are you asking me about a head curve or something? I know the operating pressure and the flow as Bosch supplies it for the application we're talking about, which is what I told you. 300 KPA/120 liters/hr.
- S
Volvo 850 power loss under hard acceleration Topic is solved
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I know what i asked you...and i know exactly how it works....question is do you know?
Fuel pump is making pressure upon restriction of fpr.
If you stick it in a jar of fuel there will be a slow steady flow....just like from tap when it's 50% opened...no squirting or pressure or something like that.It is capable to make and to push 3 bar pressure but that pressure can't be achieved without fpr in the line.
I experimented once with this while making injector cleaner/tester for my own purposes and i know exactly what i'm talking about.
The same way acts a high pressure washer of ...let's say 150bar.
Restriction is dictating a pressure.If you remove the nozzle or the hose for pressure gun...the flow from pressure washer would be just like it is from a water supply....a tap.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
Well... that's exactly why your question made no sense, and you got no answer to it, right? Which is why I said it'll deliver 120 liters per hour out of your jar. You can call that a slow flow or a spray or a drizzle or whatever you want - it'll be 120 liters per hour. And if you know "exactly what you're talking about", then that was just a bit of a sad attempt at trapping me - which didn't work at all. I think my answer also shows that I know what I'm talking about, which makes your "explanation" of it even sadder than the "clever" "trap".misha wrote: 29 Jan 2019, 11:51 I know what i asked you...and i know exactly how it works....question is do you know?
So, do you want that head curve, or are you done talking about pressure washers and sad traps, so maybe we can see what that power loss is about?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Sommerfeldt
The increase is a little weird, but your numbers seem okay but low-ish, also with that long hose and whatnot. I can't quite catch what's going on with the routing - are you able to drive with that thing connected, and video it when the power loss happens, so we can see what it does, if anything?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Sommerfeldt
There was no answer to the question you posed, and if you "know exactly what you're talking about", you should know that. If you don't, then you don't know what you're talking about at all. I still explained it to you. I even asked you to clarify if you meant you wanted a head curve (google it, smart guy - maybe you'll learn something your "experiments" didn't tell you).misha wrote: 29 Jan 2019, 12:22 You have issues.
What trap you're talking about?
I just asked you a simple question about pressure....which you didn't had an answer to....not about l/hour flow.![]()
If i asked you about photography you might knew the answer.
Pressure washer was just an example to give you a hint to understand how system works.
I don't believe what you're saying.....a trap.![]()
I know what i'm saying or claiming based on my experience and i know exactly what i'm talking about.
And you say I have issues, Stalker Bob?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Sommerfeldt
Hm. I thought you said it cut power suddenly?Jaumme wrote: 29 Jan 2019, 12:45 i definetly cant video that while driving alone but what happens is the pressure is just going down as engine rpm goes up, at 5k rpm the pressure is about 2 bar
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Jaumme
- Year and Model: Volvo 850 T5 1993
- Has thanked: 1 time
- Been thanked: 2 times
yes the power has a clean cut but not the presureSommerfeldt wrote: 29 Jan 2019, 12:56Hm. I thought you said it cut power suddenly?Jaumme wrote: 29 Jan 2019, 12:45 i definetly cant video that while driving alone but what happens is the pressure is just going down as engine rpm goes up, at 5k rpm the pressure is about 2 bar
- S
Sommerfeldt
Okay. It might be that you're simply hitting a lower limit, to where fuel flow is simply too low to meet the load demand that the ECU is seeing. Did you do the pressure testing from the PDF image that misha posted earlier?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 875 Views
Last post by Jaumme
- 1528 Views
Last post by jjlch
- 939 Views
Last post by Hardtofool
- 910 Views
Last post by bmdubya1198
- 4705 Views
Last post by June
