Has thanked: 1502 times
Been thanked: 3817 times
Re: What did you do to your Volvo today? (now Sticky!!)
Today
Driver wiper arm came loose, got caught in pass side, bent wiper blade to crap.
Replaced with spare from BMW, 22 inch
Realised it was 60F out, so broke out the vacuum pump, pumped AC system down (still at 29 inches vacuum from DEC) and charged with 750g R134A. AC working well, will measure them delta later.
Celebrated with a tank of 93 Octane
wlkstout
Year and Model: 1998 V70 na
Has thanked: 3 times
Post by wlkstout »
Removed the original O2 sensors on the 98 V70, 180k, and replaced them with Bosch OEM replacements.
1998 V70 SW 2.4l na
1992 Olds Cutlass Supreme 3.1l
1994 Dodge Dakota 3.9l
1993 GMC 1500 5.7l
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Post by jtp »
replaced the PS Resevoir. Went really smooth until I realized I had forgot to order the clamps and I didn’t have any around that for the high pressure hose connection.
Was 10pm by that point and I didn’t have a ton of options but I lucked out and Walmart had some in stock that were the right size.
Got some cheapo wiper blades there too. The streaking has been driving me nuts.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
jtp wrote: 12 Jan 2018, 21:59 replaced the PS Resevoir. Went really smooth until I realized I had forgot to order the clamps and I didn’t have any around that for the high pressure hose connection.
Any clamp should work on that if you have the same pump/resv. setup I have. The 2 lines to the resv. are both low pressure. The one that connects from the rear behind the engine (from the rack) is just a return though it sure does look beefy like a high pressure line. The high pressure comes off the front of the pump and has an o-ring in it.
brunocerous
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
wlkstout wrote: 12 Jan 2018, 19:08 Removed the original O2 sensors on the 98 V70, 180k, and replaced them with Bosch OEM replacements.
Did you have an engine code or other indication they were going bad, or was it preventative maintenance?
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
At 180k that's really smart. They get tired after 100k and will respond slower to changes in O2 content. The real danger is when they run the car lean and burn valves.
I went to 140k and replaced them
jtp
Post by jtp »
abscate wrote: 13 Jan 2018, 06:08 At 180k that's really smart. They get tired after 100k and will respond slower to changes in O2 content. The real danger is when they run the car lean and burn valves.
Good to know. Thanks Abscate!
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
wizechatmgr
*adds another item to the list for this summer...*
I've got three sets of OXS tools plus oxy-acetylene this summer
