Added one liter oil at 207800
Replaced zip tie on passenger side radiator mount with throughbolt and nut
Fabricated lower mount washer with1 1/2 inch fender washer with edges bent up to clear approx 32 mm radiator flange. Held SS PHILLIPS in place with tape, hand started lock but ( hard clearance) , then vice gripped nut And tightened from below
Inserted top rad screws with SS Lowe’s hardware
Evaluated ball joint play, 90k miles? Approx 1mm radial...need replacing
1999 V70 T5 M56 ELIZABETH 578465 Nautic Blue 417 Perfo 16 Wheels
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
- Been thanked: 4063 times
Replaced rear bumper brackets and hardware
viewtopic.php?f=1&t=57809
Master stuck oil filter thread
viewtopic.php?f=1&t=52220
Found loose lower shock cup bolt on left side
viewtopic.php?f=1&t=85762
210250
Added one liter oil, usage one liter per 2500 miles
Adjusted parking brake both side. 3 clicks max
Shoes are down to 2 mm, order replacements
Screwdriver handle moves down to tighten on both sides, adjuster is thread to right, slip to left. Threads are RH
Comprehensive list of 1999 AC Orings - some parts obsolete?
viewtopic.php?f=1&t=86140&p=478217#p478217
211800
Went in to investigate squeak in left rear wheel, occurs after 20 minutes highway driving, wheel rev dependent, changes on side to side loading
Found right parking shoe completely delaminated
Left parking shoe down to 2mm
replaced left rear bearing with Centric from FCP
Textar parking shoes and hardware
Possible left rear caliper freezing up - inboard pad is worn to groove
Source new caliper, pins, hardware, pads.
Update - replaced left rear caliper, pads - added to previous thread on rear brakes above
viewtopic.php?f=1&t=86189&hilit=rear+wheel+bearing+1999
Overcharged AC - good description of testing and evaluating a Cycled Compressor Orfice Tube AC system
CCOT
viewtopic.php?f=1&t=86562
212900 Rotated Summer tires
CCOT
213700
Flush and renewVolvo coolant, 4 liters
New fog lights
Added 1 liter oil
Discussion of proportioning front rear brake pressure at stop here
viewtopic.php?f=1&t=86918
New fog lights
Added 1 liter oil
215050
Oil filter change with M1 high mileage synthetic
Observed oil on top of cam cover origin is oil filler, new gasket!
216000 replaced air filter
New spark plugs 216xxx Volvo singl electrode
219550
Added one liter oil
221600 added one liter oil
Color code 417 Nautical Blue Pearl
Added one liter oil
