1995 850T How many miles does your 850 have?
northernlights
Year and Model: 850 Turbo 1994
Location: Florida and/or Raleigh NC, depending on the day
Been thanked: 8 times
Post by northernlights »
In my 1994 850 Turbo, my cluster currently reports 183368, compared to my current odometer reading of 183210. I have some catching up to do! The maintenance records show an odometer repair about 10 years ago, so they didn't drive for long without it working.
This is on the the stock motor which has never been apart, and might need 1/2 a quart in the 5-6k mile interval between oil changes. I currently run Mobil 1 0W40 because Walmart started carrying it in 5 quart jugs, plus a little Mobil 1 10W30 or 10W40 (based on what I have on hand) because 5 quarts is never quite enough at oil change time. I use the same thing for top off if needed.
Here's a pic from June 9 when I was checking fuel economy. This is flat cruising in FL on my 205/55R16 Conti DW's with a driveway front zero-toe alignment and 230 kPa/210 kPa F/R tire pressure (about 33/30 psi). As tire diameter is slightly larger than the 205/50R16 stockers, the speed is a few percent higher than indicated, as is the mpg.
Not too shabby IMO. As I have mentioned before, I swear the Simons exhaust added about 1.5 mpg around town, so it probably helped a bit on the highway also. A newer car would eliminate some of the tinkering, at least until it got old!
The way this car was built it seems like it can be run virtually forever (if properly maintained) if the owner didn't get tired of it, and avoided bad wrecks.
northernlights
Party time!
Has thanked: 1613 times
Been thanked: 4078 times
My favourite mechanic in Syracuse has over 300,000 miles on her V70...(Bronx cheer)
