NEW TOPIC *** JUNKYARD REQUESTS *****
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
2001 Volvo S60, but certain parts came on different models and years. Shipping would be to zipcode 43113.
WTB the following parts:
Brake position sensor, needs to be in good working condition. Part #9441116 only. Price?
Left rear door module, plus the plastic piece, unbroken, that holds the external door handle rod onto the door handle. Part #30784978 or #30699758 only. $24.
Left front SIPS module in good condition. Must come from a leather seat, with uncut wiring from the SIPS air bag all the way to the plug under the front of the seat. PM me if you need help removing the two wire terminals from the plug, or you can cut the other wires off of the plug except the two for the SIPS module. Part #8686704 or #9467747, I think. $46.
Lighted mirror sun visor for the driver's (left) side, without home link. My visor door won't stay closed, so when I have the visor down it's partly open. I would like to replace it with one that's in good shape, with no rips or tears in the leather, and that flips open and closed like it should. Interior color code is 9981. $10
Left front door interior pull handle, with all of the attaching screws holding it to the inside of the door panel plus the two screws attaching the handle to the door. The interior door panel will need to be removed to access the screws that hold it to the door panel, since they're on the rear of the pull handle. The pull handle is two pieces. You'll need a small flathead screwdriver to pry the two halves apart, starting from the bottom and working upwards, to remove the two mounting screws, and to remove the door panel. They're all torx screws. Interior color code is 9981. $18 for the entire door panel, so $10 for the pull handle and all screws.
I would prefer that the interior parts match my 9981 trim code, please.
Prices listed are for the closest Pick N Pull to me, plus the $1 to enter the yard. Prices do not include shipping cost.
Dave12345
Year and Model: 2001 V70XC
Post by Dave12345 »
Want Chocolate Brown Passenger Seat for 2001 V70XC. Also looking for rear hatch/trunk interior - beige. Will pay and pick up from you or will negotiate shipping.
Has thanked: 1611 times
Been thanked: 4073 times
Junkyard request for teal green , color code 412, rear tailgate for 1998 v70
Located upstate NY, can pickup anywhere in NE radius of 500 miles
Need P2 front fenders and hood for an XC70 in 417-26, nauticBlue Metallicpear
This awesome colour cAme in the 2001 2002 2003 and 2004 years in P2
Located upstate NY can pickup anywhere in NE radius of 500 miles
Dave7777
Year and Model: 2001 Volvo V70 XC
Post by Dave7777 »
2001 V70 XC ... looking for chocolate brown front seats and beige interior panel for the rear hatch (complete). Also need under the seat amplifier and the motor for sunroof (and the sliding door that covers the moon roof ... being please). If you find some, message me so we can negotiate price!
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
2005 - 20011 XC90 V8 Part number 30731477. It is a bracket that hangs the exhaust pipes from the transmission. It keep the pipes and manifolds from cracking when the engine torques. One might call it a anti-flex.
Active
Past
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
RickHaleParker wrote: 06 Nov 2020, 02:05 2005 - 20011 XC90 V8 Part number 30731477. It is a bracket that hangs the exhaust pipes from the transmission. It keep the pipes and manifolds from cracking when the engine torques. One might call it a anti-flex.
If there's anyone near Greensboro, NC seeing this, they just got an XC90 V8 at LKQ Greensboro this week. Would be a good opportunity to grab this part. I wish I was closer to GBO.
These are the M7 x 30 mm black oxide flange bolts that hold the IM on our cars.
They are not easy to source outside the Volvo parts world.
Please harvest these - I would like to coalesce a large collection of 25 or so and can send on to those in need.
If you are really in a bind Dorman makes one
Dorman 423-330 M7-1.0 x 30mm DIN 'Class 8.8' Hex Head Cap Screw - but it is $12
gnalan
Post by gnalan »
abscate wrote: 06 Nov 2020, 10:03 These are the M7 x 30 mm black oxide flange bolts that hold the IM on our cars.
That's a pretty good idea. I wouldn't just limit it to those bolts though, since new bolts are outrageously expensive from Volvo. I just bought a bunch of nuts and bolts from FCPEuro, that are genuine Volvo parts, and they weren't cheap. I think any reusable bolt that can be harvested should be. Volvos are hard to find close to me, but I would grab everything I could, and have several baggies to label what the bolts come out/off of, if there were.
RickHaleParker
Part number 982778 is also used on some engines to:
1. Bolt pulleys and VVTs to the camshafts.
2. Jet cover to cylinder blocks.
3. Intake manifolds to cylinder heads.
4. Some brackets for Intercooler charge pipes.
5. Brake Vacuum pump.
At a glance, it looks you can find 982778 on just about any RN engine not just the P80 & P2cars. Does look like the RNC engines use a different bolt.
I never throw bolts away, learn that a very early age. When I go picking I keep all the bolts I take out and find laying around.
I bet a got a bunch of 982778 in my bolt box from the Junked B5254T4. I'll go through my bolt box and see if I can contribute the MVS socialized stock pile.
Active
Past
