850 T5 Blue Smoke after a couple hours of sitting
fantajuice
Year and Model: 1995 850 2.0 T5
Been thanked: 2 times
Post by fantajuice »
Do all of them have cracks inside the manifold, turbo side?
I've seen 8 and all of them do.
fantajuice
The heater fan decided to give up. Will it only fit from a 850 or will the first gen v70 work too?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
fantajuice wrote: 09 Nov 2020, 22:01 The heater fan decided to give up. Will it only fit from a 850 or will the first gen v70 work too?
Did you check to make sure it is the blower and not the resistor pack. Pull the wire off the blower and connect +12V to the blower.
1993 - 1997 850 only. Volvo part numbers 6820812 and 6849562. In the US Volvo OEM is ~$270.00 .
You can save a bundle if you can locate the motor only then use it to rebuild the blower. You will end up a blower that has OEM performance. The motor is Bosch 0130111134. In the US we can get the Bosch 0130111134 for ~$60.00. A difference of $210.00.
Active
Past
fantajuice
I think I found a second hand one from a scrapper.
The old one melted fuses before it died.
I got rid of all the turbo leaks and the car happily burns rubber in third gear. However - how long does the 15G turbo last at 1.5 bar boost and a ECU tune? Starting to get worried I might kill the thing.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
fantajuice wrote: 10 Nov 2020, 06:42 I got rid of all the turbo leaks and the car happily burns rubber in third gear. However - how long does the 15G turbo last at 1.5 bar boost and a ECU tune? Starting to get worried I might kill the thing.
22 psi? Who told you that was a good idea on a 15G?
As to how long... not very. You're probably making mostly heat running a 15G at that level, so if you're really after performance, a turbo upgrade along with new IC should be up top of the list.
- S
[Sold] '97 S70 T5
Has thanked: 1610 times
Been thanked: 4070 times
fantajuice wrote: 10 Nov 2020, 06:42 I think I found a second hand one from a scrapper.
The turbo will last forever
The connecting rods, your first full throttle 22psi pull.
Sommerfeldt
abscate wrote: 10 Nov 2020, 06:55 The turbo will last forever
Will it, though? ;)
22 psi is quite nuts on a stock setup in any case. Boost will kill the connecting rods, or the 15G will make nothing but heat and cook the whole thing... It's up there on 19T levels, after all.
- S
[Sold] '97 S70 T5
fantajuice
Sommerfeldt wrote: 10 Nov 2020, 06:51
- S
Thing is, I didn't tune it there, it was like that when I bought the car and I have no idea what has been done to the car. Boost takes ages to build anyway. And it did make 1.5 bar unless the gauge is way off.
Sommerfeldt
fantajuice wrote: 13 Nov 2020, 10:54 Thing is, I didn't tune it there, it was like that when I bought the car and I have no idea what has been done to the car. Boost takes ages to build anyway. And it did make 1.5 bar unless the gauge is way off.
Sorry about the slow reply.
Your car shouldn't see anything above ~0.8 bar stock, so someone did something, or your gauge is off. I wouldn't call 1.5 bar a safe level either, and on a 15G, boost is normally quite quick - even on a 16T, you shouldn't really have significant lag...
It seems to me that there might be some things going on with either the turbo or the control mechanisms - your wastegate or actuator could be stuck or jammed in some way, to make it slow to boost and then not stopping at the correct level. I'd expect other problems if you're boosting that much over stock without other changes, so someone may have done it on purpose...
Check your codes, check the gauge, check your boost management and then ponder flashing your ECU with a stock map, just to reset things since you don't know what's been done before. That last one is involved, though, so unless you're having other engine issues, it might be a bit over the top if you're not planning on tuning it yourself or upgrading things.
- S
[Sold] '97 S70 T5
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
So now I'm curious - When Sveedy was completely stock I noticed that the stock dash turbo gauge didn't rise above about 3/4 of the way into the white under wot. Now with mods I've made I see the gauge go all the way to the far right, basically burying the needle. Any idea what the stock gauge is calibrated to ? I'm I developing too much boost when it goes that far into the white zone ?
1999 V70 GLT
