Check out my posts again - I am always referring to the eyelet/hole (unoccupied), not the notch (occupied). Check out Al's pics, the arrows point the the little eyelet/hole. The eyelet/hole is covered by tape in your pic. It's almost certainly what you put the wire through, I am guessing.Sveedy wrote: 04 Dec 2021, 08:25 On my latch there is a cable in that notch. And you push the tab toward the outside of the car. if your standing in front of the car, the tab pushes toward your right ( drivers side wheel ). At least that's how mine works.
I think the cable that is hooked in that notch activates the passengers side latch.
There are two cables from the factory: one from the cabin to the driver's side latch, one from the DS latch across to the passenger latch.
I will take the fifth on which direction the latch needs to pull on a 98. I just know it's super easy to hook a cable through that eyelet and have it work. But it would be outside the spirit of this thread to simply say that.
