ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
smacknab wrote: 27 Sep 2020, 08:50
ZionXIX wrote: 26 Sep 2020, 21:33
You should check for rust at the bolt points where the heat sheild above the catalytic converter bolts into the inner footwells. Mine seems to spill over and drain into those holes and one of them rusted out pretty bad. My indie said it's a problem he sees alot with these cars too.
Texas has gifted me with +10 rust resistance.
bmdubya1198 wrote: 27 Sep 2020, 08:46
Wow, that's a lot of water! Clean out your cowl drains and make sure there aren't a bunch of leaves and junk in the cabin filter/inlet (not sure if your car has a filter).
I keep the cowl very clean and I added a cabin filter last year. I also thoroughly vacuumed inside the housing when I replaced the fan and resistor. What ever is stuck in the drain has been there for years. Im not about to tear the dash apart to clean it until I'm ready to replace the evaporator.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Replaced fuel pump with a DW200. Had to do a little modifying of the suspension basket, but other than that easy pezzy.
1999 V70 GLT
Sufbug
Year and Model: 1998 V70
Has thanked: 2 times
Been thanked: 2 times
Post by Sufbug »
Not today but yesterday....
1998 volvo wagon.....
------new oil cap rubber
-------lube hood latch
-------------blow out the sunroof drains
------find exhaust leak---patched with smuutch lol
---- trw rack new rubber boots
------check all brakes 12 mm front. 5 mm rear
-------balance tires
-------mount and clean wheel speed sensor from pass
-----sunroof doesnt work ..lubed and operated.
-----moonroof doesnt work lubed and operated
-------winter button is intermittent...loosened up
------new oil filter with magnet on drain plug
1998 V70 wagon / 244,013 miles / purchased 9-25-2020
2016 Cadillac CTS4 / might be selling this
1979 trans am 400ci / 4 speed / t-tops / not selling this
Sufbug
Post by Sufbug »
Also was putting on a new cv boot on the pass side, and broke the bearing race. Don't ask....but now gonna call fcp and see how quick I can get an axle/cv joint/or cv bearing race.... Grrrrr
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
ZionXIX wrote: 26 Sep 2020, 21:33 Cleaning the AC drain hose made no difference. Barely poking through with a zip tie unleashes the floodgates. I think something is trapped in there acting like a 1 way valve. The zip tie has zero resistance going into the drain but is very difficult to remove. Not sure if that is normal.
My fix involved placing the zip tie in the drain hose and leaving it there. So far today its never worked better.
That IS a lot of water.
It's curious why that zip tie is working. There's not some sort of flapper valve in there, is there? And why would there be? So as others have said, it could be a big leaf and a bunch of goo, and you're just pushing it out of the way temporarily.
Do you have any way to put some air pressure in there - reverse - and push all that out? Compressor or a necked down shop-vac hose on reverse (blow). Or even scrub it with a small plumbing snake and pull it out, then rinse.
Has thanked: 1502 times
Been thanked: 3813 times
Got the fuel filter off and found the fuel leak onGrunhilde.
Now she can move under her own power. She is fighting for her life vs a part out
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
smacknab wrote: 27 Sep 2020, 08:50 You should check for rust at the bolt points where the heat sheild above the catalytic converter bolts into the inner footwells. Mine seems to spill over and drain into those holes and one of them rusted out pretty bad. My indie said it's a problem he sees alot with these cars too.
Never heard of anyone else with this issue, but I'm glad I'm not alone! I have a little spot of surface rust here, not nearly as bad as in your picture but it's the only apparent casualty of the car's life in the Rust Belt. The rest of the car is so straight despite 15 years around the Northeast and Midwest that even a little speckle of brown startled me.
ZionXIX
Post by ZionXIX »
BlackBart wrote: 27 Sep 2020, 17:21
I could position the air compressor gun under it but its only going to move things around. I suppose I could use one of those finger snakes to break up some of the material. I wish I could see it. I though about sending an endoscope through the center vents. Im just happy its working right now.
Trolling the regulars here.
Does anyone remember a thread about someone doing piston rings by pulling the piston down through the sump after removing the oil pan, or have I been breathing in too much brake cleaner again?
P80 NA 1998
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
abscate wrote: 28 Sep 2020, 09:53 Trolling the regulars here.
P80 NA 1998
Seems like it was mentioned in the last month. I don't remember any details. Looks like it would be real fiddly to use a ring compressor from the bottom.
