I would never clamp a brake hose that I intended to use. If it was a hose I was going to cut and toss before the vehicle ever came off the stand, sure, but I would NOT intentionally introduce sharp radius bends in to a vital piece of safety equipment (no different than not letting a caliper hang by the hose, IMHO) merely to avoid loosing some $8 brake fluid. The risk-vs.-benefit is not viable for me.cn90 wrote: - The "good side", i.e. LF caliper, I rebuilt it anyway using ATE seal kit as written in this thread.
During the rebuilt, I got "lazy" and did not want to run the air compressor, so:
* Clamped the brake hose (used card board as cushion).
To give some idea of what happens, look at happens when a section of hose (left) is clamped (right). Both have the same circumference for the I.D. of the inner hose and thickness for the inner and outer. By clamping it the outer has to span almost two and a half times that of the inner (3/1.23) which means the inner gets compressed while the outer is stretched. This is why folding or pinching garden hoses kills the so easily and leads to leaks at the points of most concentrated flex, but they do not have to stop a 3,000 lb vehicle.
Neither I nor any brake hose will last forever, but that doesn't mean I care to hasten either's destiny! For anyone interested, the following have some photos of brake hose construction:
http://www.brakehoses.org/brake-hose/ru ... -hose.html
http://www.brakehose.co.za/hosespipes/cef_rubberbrakehosespec.html
http://www.brakehoses.org/brake-hose/hy ... -hose.html
