- Has thanked: 304 times
- Been thanked: 517 times
Well that was easier than it could have been!
- Has thanked: 1505 times
- Been thanked: 3818 times
I channeled my departed father on that one. He once shut down an engine line for Saturn V when a bunch of engineers were scratching their heads over a bad measurments, told every one to go home and get their equipment recalibrated.
He was right on, everyone was basing their data on a single measurement of one device out of whack
He had a number of lessons about being as careful with your instrument as the device under test
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
^^ Amazing.
That's a question I've never figured out.... Extreme accuracy measurements need to be made by machines, which were measured by some other instruments, which were made by other machines.....
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 336 times
Well, in my defense, while the reading was low, I was getting what seemed to be corroborating measurements from the two different circuits on the meter.abscate wrote: ↑20 Oct 2020, 12:15 I channeled my departed father on that one. He once shut down an engine line for Saturn V when a bunch of engineers were scratching their heads over a bad measurments, told every one to go home and get their equipment recalibrated.
I was glad to have access to another measurement device in the test lab. I just pulled the bulb when I got home from work, so we should be good for the time being.
- Been thanked: 1000 times
If you are serious about accurate measurements, your instruments are calibrated periodically. The calibration shop has theirs calibrated often to a better standard. If all is done properly, this chain leads to a national/international standard with very high precision.
You probably knew all of this...
- BlackBart
No, I did not. It's all fascinating. Who designs, machines, measures, and calibrates the calibration tools? I assume at some point you use light and lasers to measure surfaces....?
I have to get out a magnifying glass to figure out which line on my old non-digital hardware store calipers!
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
In the USA, we have NIST, an agency of our Department of Commerce, which maintains the national gold standards for instrumentation calibrations. We say our measurements are "NIST-traceable" if there's a recorded chain of calibrations from the instrument you hold in your hand back to NIST, or to some other organization which NIST certifies as being capable of calibrating instrumentation to its standards.
Various industries then maintain their own quality standards (ISO9001 etc), which usually state that a manufacturer must use instrumentation making NIST-traceable measurements on the production line. That way when you ask for something to be 2.11025m, it's the same 2.11025m at the rocket company's factory as at the satellite manufacturer's factory, and you can expect the parts to fit together correctly.
j-dawg
Oh, you're from Montana! The Swedish flag threw me off.
Doesn't really change anything about what I said, but somehow I feel like it's different writing to someone in another country.
It is another country, one of Grizzlies and Cats..
For more info on NIST
https://en.wikipedia.org/wiki/National_ ... Technology
Without standards there would be chaos in industry. At the beginning of the industrial revolution, each shop had their own design for nut and bolt threads. They did not interchange with other shops! I believe this was one of the first industry standards.
