Has thanked: 1498 times
Been thanked: 3810 times
Added to the most useless Volvo P80 trivia databank
The two bolts holding on the lower timing belt cover
Part 985031
Are M8 bolts with 10 mm hex head
Good luck finding those at hardware stores
I went to Tasca and they have had to special order from Volvo in Sweden. Might be good hardware to harvest from Southern junkyards
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
kallekula wrote: 02 Nov 2020, 09:49
Cheap to buy but expensive to own if you don't know how to wrench a bit yourself. They are a blast to drive though once you get em to run properly!
For sure!
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
kallekula wrote: 02 Nov 2020, 09:43
MoVolvos wrote: 01 Nov 2020, 23:17
kallekula wrote: 01 Nov 2020, 21:50 Yeah it's the first car I bought when I was "fresh off the boat". It holds some kind of sentimental value to me. During this period I think I managed to log around 50K miles. It serves as a very reliable 2nd car to us. We use it when camping, getting the xmas tree etc. So yeah, I really like that car and I pamper it a little too much sometimes 😀
Reminds me of my 83 GTI. Cleaned it once a week it seemed like. Yours can fetch a huge sum on Bring A Trailer. White and silver I think were the two best colors for the S70's. BTW: FOB 1971, if that's what you mean. Here it is (was) mine, again, $500 for the car & $200 for the 1K mile old tires and rims combo from CL.
How are those 16" tires on the car? Went to the V70 15" for a better ride though it came with the same turbo wheels but with very old and hard tires to begin with. When my last one leaves the coup I think I'll make you an offer you can't refuse :wink:.
Nice car! Tires work fine, just some rubbing if you turn sharply but it's my absolute favorite Volvo wheel style.
I would buy another silver S70 T5 w/rear spoiler if it were in great shape. I also noticed the 16" rubbing the front inner liner before changing them out besides the entire strut assembly.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I had a 99 auto T5 with the LPT block in it. It was a fun car!
BMW 540i 2002
S70 Base 2000
MoVolvos wrote: 04 Nov 2020, 17:42
My T5 came with stock 16 inch Perfos and has never rubbed. Do you have the poly white plastic stops on the lower control arms?
kallekula
Post by kallekula »
abscate wrote: 05 Nov 2020, 03:36
I do. Could probably glue something thicker onto it but I don't care so much about the rubbing.
BMW 540i 2002
S70 Base 2000
MoVolvos
Post by MoVolvos »
No, back then I didn't know it existed. Not sure if I experience any noise but I did lube the metal surfaces of the stops.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
kallekula wrote: 05 Nov 2020, 11:04
You can also increase the bump stock thickness by adding one or two washers behind the bump stop mounting bar. SAE 1/4 flat washers work fine.
kallekula
Post by kallekula »
Trying to get some better mpg I mounted a new O2 sensor. I have no idea when it was last changed. I checked with an OBD2 reader and the new sensor seems to flip/switch voltage faster.
I'll get back with results in a few days.
BMW 540i 2002
S70 Base 2000
Our sensors look just like that.
Let me guess, you just put a 22 mm on it and screwed it off...
